Ian's car revving adventure shows some faith in it's internals.
With the stock sc cams, it doesn't pull as hard past 6000, thankfully, I wouldn't have the guts to let it sit there at 7krpm. But it does pull very nicely to 6000rpm. I love the 81 cis, around the 10th year of cis development for the 911, so it'd better be the best. |
As I mentioned earlier, that made a difference and allowed me to reach red line, only Not as vigorously as I would like. I'll check the timing as per Ian's recommendation and see what that gives. If I had the resources I would like to swap out the cams for the ones Ian is using. But we all know swapping out the cams on a 200K mi engine could get very expensive and at this stage of the game I don't think I'm ready for that expenditure Thanks |
The throttle rod coupler can wear out and cause the throttle plate not fully opening.
https://www.pelicanparts.com/More_Info/91142308102.htm?pn=911-423-081-02-M260
Dave K |
Eng-o-neer
If your car starts sputtering above a certain RPM, it's not throttle related. When does it sputter? Wide open throttle? Partial? Is it struggling to make enough power to move the car faster? All gears?
My money is on timing and fuel delivery. |
I think Hugh is reffering to a lazy feeling of the engine, not wanting to charge to redline . Not based on a missing of spark or fuel. If the advance is incorrect then that might do it . Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
If you have the time, Try removing the rear silencer just as an experiment, and see how much quicker the car gets to the red line,[yes it will be quite loud] if it has the original back box still in place it is surprising how restrictive it can be at high RPM.
Just a thought from my own experience.
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
hughc |
Ian's first gear, speedo is in km/hr.
Thought it was 2nd in mph with different gearing. For first gear, it seems about right, looks similar to mine without being too picky. Someone stripped out cat, otherwise stock but I rebuilt top end. I think it pulls faster on mine till around 5800, then it would die off and Ian would blow by me. Phil Last edited by ahh911; 10-20-2022 at 02:01 PM.. |
There's a difference between revability in gear and in neutral
in neutral it depends on the rotating mass, cams, cr and exhaust, assuming all is nominal in gear it depends on gear ratio, which includes cwp and tire OD, rpm, and mass of the vehicle as well as the base items in the neutral rev scenario all cis 911s peak out hp at ~5500 hp and have heavy stock rubber clutch disks and tall gearing for fuel economy, none wil rev like an earlier engine w/ l/w clutch, fly wheel crank , cam timing and freer exhaust
I've read/heard somewhere that you shouldn't rev the car too much in neutral. It should be under load when you are giving it some revs. |
I too have heard not to rev unless under load, but, when I switch to the next higher gear, lot's of times I'll push the clutch without releasing the gas pedal quickly enough and am pretty sure revs blip to 6krpm and above, freewheeling for a second, so, don't know what to say other than it happens from time to time, though not intentional. Come to think of it, every time you shift the engine is freewheeling? Shift properly at 6000rpm and the engine is freewheeling till the next gear and clutch pedal is back up.
In first gear, I don't have an lsd, if I punch the gas while rolling at 2000rpm the tire breaks traction by around 3000rpm. Second year on pilot sport all seasons, the decent ones, but they're getting worn. My point is, there is a lot of grit down there and it will fly to 6000rpm very quickly but you need some skill to keep the wheels from spinning. This is a rolling start, so no clutch drops whatsoever, I never thought the car would be this fast, maybe one day an lsd. Last edited by ahh911; 10-20-2022 at 05:17 PM.. |
M1 cams will provide GRUNT, but you need to give the engine the fuel it needs to make the power . I can get 0-60 in 5 secs flat if all the stars align .
1/4 mile in 14.0 at 101 mph and no burn out . all that at 8.0-1 comp ratio, my car is a street car, pulls great @ less than 3,000, it has to, to to get the low time numbers I beat the 2018 honda civic type R all 4 races as well as the WRRX STI subie . The feel of this cam is power and smooth with a charge at 4,000 to 7000 all this on a stock internals 3.0 , Stock spring plate clutch and steel pressure plate , SSI, dansk 70 mm sport muffler , 205/60/15 front , 225/60/15 rear tires , 45 mph 1st, 73 2nd ,103 3rd , 131 4th , 146 5th 28 mpg @80 mph, Porterfeild R4S brake pads , 228 hp at the crank ,in this config , on mustang eddy brake dyno, Just about the most fun ever ! Ian
but even so relatively small changes in the engine rotating mass make noticeable differences in the slope of the rev acceleration curve. I recently experienced this in one of my 993 engines, It's a 3.6 993 in my '76 C3 w/ RS cams and custom Wong chip, Fabspeed headers etc, went from steel to an Aluminum Sport Clutch, The difference in mass was only a few pounds but the engine response both loaded and unloaded is phenomenal, there was a corresponding reduction in lug ability of the motor additionally, this motor revs considerably quicker than the 3,8RS in my 993 w/ much heavier g50 competition clutch set up As to revving in neutral, you do realize that from day one that these cars were timed at 6k rpm in neutral
Maybe a touch more compression, cams were SC reworked, timing was set at the point where max valve to piston clearance at edge of timing spec. No cat, regular exhaust. 81sc usa. I don't know why it's contrary, but at 5800-6000 rpm the car gets a final deep breath, then backs down. It seems to pull harder than anywhere else at that final stretch, in 2nd it most noticable. Why is that 500 rpm more than others? Am I full of it? But there have been many times where this last blast arrives and I'm thinking wow, where did that come from? Some sort of deception, power back down, vacuum advance kicks back in and off it goes again? Don't think so, is there something with my timing and no cat pulling in more air showing a hint of what's possible? Don't know. I didn't mention this earlier figuring no one would believe me. I just did it again several times today. Phil Last edited by ahh911; 10-23-2022 at 01:44 PM.. |
My '82 Euro that's had the internals balanced, SSI's, doesn't back off at any revs. I've red lined it in top gear and it was keen to go faster. I wasn't.
Between 5700/5800 and 6000 it's a weird sensation, as if all of a sudden air is available freely and flows with ease through the engine, it just feels effortless at that point and it just whips the car along. (Breathy, is that a word?) Also, with free rev talk being the subject of this post, I hung around 6400 rpm the other day, there was a slight high frequency buzzing sound, very faint, that didn't appeal to me. Last edited by ahh911; 10-23-2022 at 02:58 PM.. |
Eva
After I replaced my rubber clutch that is... The rubber was good, but certainly not great
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
![]() torque peak/hp peak 1976 911 S 4000/5800 1976 Carrera 3.0 4200/6000 1978 US/ROW SC 4200/5500 1980 SC/RoW USA 4200/5500 1981-83 SC US 4200/5500 1981-83 SCRoW 4300/5500
My 1979 Euro engine had some low down torque, and ran out of steam at high revs. Well, not really ran out of steam but there eas no point in going over 5,000rpm because it didn't have any power gain.
But my 1982 Euro is a completely different beast. No low down power but the more you rev it the more power it gets. Red lining it in top gear it was feeling lively and wanted to go faster. No rubbber centered clutches. I think they were swapped out many decades ago. |
