Potential Oil Pressure Loss with Carrera Chain Tensioner Upgrade ?
All
My 77 911S is making some engine rattling noise on ordinary acceleration, thinking it may be time to check the timing chain and likely get the hydraulic tensioner upgrade kit. Is there any concern about oil pressure loss on a stock 2.7 engine ? I'm asking because I've seen a few posts regarding oil pressure, just wondering if this applies to my engine.
So while I'm in there thought it also best to change the chain ramps and upgrade the idler arms, do I need the shaft spacer if using the later idler arms ?
Tony
1977 911S Irish Green
Old 10-05-2022, 01:58 PM
Red Line Service
Marc Bixen's Avatar
Order these also: 901 105 361 02
It's an upgrade cam oil line fitting that keeps more oil in the sump pan, prevents low oil pressure from oil aeration. I believe you'll need spacers for this upgrade also 930-105-513-00
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 10-05-2022, 03:10 PM
Late idler arms are wider and don't use spacers. It's not like the carrera tensioners spray oil out sufficiently to cause a pressure drop. If your engine puts out 60# pressure, you won't notice any difference. The cam fittings with a smaller bore can raise system pressure, but less is going to the cam and rockers. Your call.
206 637 4071
Old 10-05-2022, 05:11 PM
prschmn's Avatar
But what's the "rattling" noise? Bad tensioner noise is going to most prevalent
at idle.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 10-06-2022, 07:37 AM
Gosh, hope its not a broken head stud. Similar noise. Did u listen with a stethoscope to isolate the rattle at idle? Last time the valve covers removed, v adjustment, or any top end rebuild?
Old 10-06-2022, 05:37 PM
