AC system install on a 911t
I’m looking to buy a 1972-73 911t with out A/C. Can I have the original AC system option added? Help
Old 10-07-2022, 08:33 AM
Probably go with the Classic Retrofit electric A/C. I'm going this route eventually but my SC came with A/C so not sure about a car that never had it.
1979 911 SC Gran Prix White. Gone but not forgotten.
2016 GT4, current steed.
IG @hulley31
Old 10-07-2022, 09:31 AM
Counterclockwise?
Was it not a dealer install back then?
Rod
1986 Carrera
2001 996TT
Old 10-07-2022, 09:35 AM
The AC would be a retrofit and some offerings plumb into the “original” ductwork, that’s about original looking as it gets.
The old dealer installed units had bulky under dash vent console fitted in place of the knee pad. I removed my AC and this vent box and will eventually find a replacement knee pad to keep it looking clean.
The old original AC performance has always been disappointing in warmer climates, but did the job as long as they were used. Most AC fails are due to lack of use which dries out the seals and that’s applies to all cars. Air cooled Porsches tend to be seasonal drivers and ac systems are idle for months year after year.
Old 10-07-2022, 09:39 AM
Griffiths is a better fit for older cars
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 10-07-2022, 11:44 AM
I did a Classic Retrofit on my '71 911 and couldn't be happier fairly easy install, super clean.
1971 911T British Racing Green 3.2L
2013 981 Boxster S Aqua Blue/Grey
2014 981 Cayman S Agate Grey/Black
enjoyed and passed along:
1990 964 C2, 2007 C4S Cabriolet, 1997 986, 1958 356 A
Old 10-07-2022, 12:24 PM
Send a message via AIM to fintstone
Yep. As long as you can find the parts. Most folks would upgrade as the original system was not very effective. Most would get a modern compressor, condenser (maybe add one or two), evaporator, and barrier hoses (you could reuse the underdash vents which distribute air pretty well and keep it looking relatively original if you chose to upgrade).
You would also need a different pulley (if a non A/C car) with an extra groove to pull the belt to run the compressor).
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 10-07-2022, 06:53 PM
HarryD's Avatar
My 1973.5 has “dealer” AC.
It has been removed and if I was to reinstall, I would go the electro cool route. Keeps the engine room clean, and is expected to be more effective.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-08-2022, 08:28 AM
IMHO even though the engine compartment is cleaned up, all those extra hoses in the trunk for electric are not my cup of tea. At least the installs I've seen here.
Still not seen real evidence that it will work in really hot climes.
1991 C2 Turbo
Old 10-08-2022, 10:44 AM
Can you post what vents you are using? The electric AC vents has the air blowing towards your knees? Did you modify to get more air directed to you face. Enough volume of air to feel it on the face of driver and passenger
Ray Crawford
1972 911 S Targa
1973 E Flairs n Chairs
Old 10-12-2022, 06:38 AM
Counterclockwise?
I've been trying to sell my box of AC parts for years!
Rod
1986 Carrera
2001 996TT
Old 10-12-2022, 08:10 AM
My other ride is a C-130J
RNajarian's Avatar
There was a time A/C threads were the Wild Wild West here at Pelican.
The subject has dozens (maybe over 100) of threads on the subject.
Below is a link to several of the threads I started here on Pelican. I reinstalled my dealer A/C with pretty good results using all used OEM equipment (except for the dryer.) Good luck with the project. Keep us updated.
https://forums.pelicanparts.com/porsche-911-technical-forum/769156-holy-grail-air-cooled-911-air-conditioning.html
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 10-12-2022, 09:17 AM
Love to see pictures of your trunk, to see how you handled the ductwork
1991 C2 Turbo
Old 10-12-2022, 11:11 AM
Eng-o-neer
Tremelune's Avatar
The answer is yes, but it's about $5k in parts any way you slice it.
Old 10-15-2022, 11:06 AM
Eng-o-neer
Tremelune's Avatar
Where did you put the condensers? I have this dream of putting two up front, along with a Carrera fender cooler...and I'm not sure it's possible with those two battery boxes up front...
Old 10-15-2022, 11:07 AM
hheine's Avatar
No way around it you’ll need to cut into one of the battery boxes
Old 10-15-2022, 02:53 PM
for those that took it out, can i have the under dash vents?!
Old 12-14-2022, 12:41 PM
I always thought this too, until I saw a 73RS that Kondrasheim sold recently in BAT.
Since the euro cars did not have a fuel expansion tank in the left fender the car had a condenser with a fan in that location. Pretty slick. No rear condenser.
I don't know where you could relocate the tank for US cars.
1991 C2 Turbo
Old 12-14-2022, 12:48 PM
Bucketlist's Avatar
Several years ago I put an aftermarket ac in my SC Turbo which didn't have factory air. Retroair is out of business now but there are others selling a similar kit. My best advice is to use new state-of-the-art parts in whatever you do because the newer technology is well worth the money.
Retroair complete system in my non a/c car
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 12-16-2022, 02:51 AM
HarryD's Avatar
If it was me and getting all 100 points for the Concours was not important but being cool was, I would go with the ElectroCool system.
https://www.classicretrofit.com/en-us/products/air-conditioning-kit-for-classic-911-full-kit
Harry
2020 MB E350 4Matic
Old 12-16-2022, 01:27 PM
