looking for help on unusual engine serial number
Hi All,
Trying to help figure what this actually is. I know the pictures are not the best, engine was in a corner and not easy to access. Serial number looks to be 901 332 or *01 332* which doesn't line up with 911 serial number listings I can find. ![]() Could not get good picture of type number ![]() Engine is supposed to be a 2.7RS spec engine purchased loose from the factory back in the day. The pistons and cylinders look correct for the description. Could not get in closer to clean and see numbers better. Did loose engines back in the day have different serial numbers? I once had a car with replacement case and no serial numbers, so I know not all cases line up to listings. Thanks for any info. John Last edited by targa72e; 10-16-2022 at 01:11 AM.. |
You are correct in that Porsche did assign different types of number ranges at times for replacement engines. Get in there and clean up the area where the type # will be and report back to us
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
I hope to get back at some point and clean the area to see if there is a type number stamped.
thanks, john |
anyone have any info?
john |
well? did you get to the point of cleaning it up so you could be helped?
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
That is the aluminum engine case of a first series 901/01 engine with serial starting at 900101. If you clean the area behind the serial # and locate the type # 901/01 you will also find the number 1232 which tells you precisely how early the engine is. You desperately need to update your search criteria for 911 engine serial #'s.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Looks like 901 332. Per this site, it is an early 1965 2.0 L motor. Should have a stamp 901/01 nearby.
https://www.stuttcars.com/porsche-911-engine-numbers-1965-1989/
Thanks for the replies. Engine is not Aluminum case, I know what those look like. Engine is buried behind other Porsche stuff, had my arm at full length to get what I could of pics, Buried back in a corner behind parts. I hope to get back to clean engine enough to get better pics of numbers. Lots of interesting stories to go along with parts (speedster engine was on bench). This engine was purchased from Porsche factory in 73/74 as loose engine. It was purchased by ex-racer with close ties to factory (racing speedsters, 904's, 356 etc). It has been in storage for 40+ years. I am trying to find out if there is a listing of engine serial numbers that were not sold with cars and maybe use a different numbering system. I do not know if loose engines even have a type number. Hoping some info from people there involved with racing back in the day when you just ordered up a spare RS spec engine might have some insite.
john Last edited by targa72e; 11-06-2022 at 09:22 PM.. |
Oddly, on my computer, it looks like it is aluminum.
John Thompson Eugene, Oregon |
