Targa_PB_78_SC
mike sampsel's Avatar
Take a heavy gauge electrical wire you can wrap around the ball socket, leave ends to grab with a pliers and pull the socket straight off. Just remembered it worked for me.
BareRearedRookie
Old 12-02-2022, 03:56 AM
Originally Posted by wgirardot View Post
try separating the ball and sock below the one shown in your picture, worked for me
Yeah do the one on the bellcrank side, for whatever reason it's easier. Big screwdriver jammed between the socket and the arm.
For the fuel lines, don't buy anything from these guys ( ) but their engine removal blog has some great photos.
https://blog.*******.com/how-to-remove-engine-gearbox-classic-air-cooled-porsche-911
the asterisks are FCP euro
1982 911SC
Old 12-02-2022, 05:36 AM
Can I unthread the rod to separate it? Or do I need to cut it and replace.
Old 12-02-2022, 10:43 AM
Technically yes? Just pop the sucker off, man. Jam a big screwdriver in there, turn it and pry it off. So long as it doesn't have the little retaining wire in place it'll go with enough force.
1982 911SC
Old 12-02-2022, 10:57 AM
ADDvanced's Avatar
Pop it off. More power!
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 12-02-2022, 10:59 AM
Must still have the clip inside because I'm bending the lever
Old 12-02-2022, 11:22 AM
Try this, then. Unbolt the throttle linkage mount from the engine, disconnect the looong throttle linkage down at the transmission bell crank, then pull the whole linkage assembly out with the airbox/throttle body. Once it's out you'll have more options and leverage to inspect it and pull it apart, then you can clean up, grease and reassemble while patting yourself on the back.
Actually, I'd suggest doing that anyway because the bushings in the throttle linkage bellcrank are more than likely in bad shape and need replacing. Easy job to do if you have it all apart.
1982 911SC
Old 12-02-2022, 11:40 AM
Finally got it off. I was able to loosen the rod and undo the nut to release some of the tension on the ball cap and came off easily then.
Do I disconnect the fuel line to the accumulator and at the top of the fuel filter?
Old 12-02-2022, 01:09 PM
Finally got it off. Now to clean it all up and replace old parts.
Old 12-03-2022, 01:38 PM
Good Job........
Joe,
Congratulations! You have achieved your goal removing the complete CIS in situ. Time to move to the next level. Learn to drop the motor this time. Once you done an engine drop, you would realize why knowledgeable and experienced people prefer to remove the complete CIS on an engine stand.
People who had attempted to remove the complete CIS in situ have not done an engine drop before. And I don’t blame them for choosing to do it in situ. The fear and anxiety is too much to overcome for some people.
Just imagine installing the CIS unit back with the motor on an engine stand and sitting on a comfortable chair on wheels and finishing it after a few hours. Use your imagination how easy and wonderful to work on your motor if you had removed it........
Tony
Old 12-03-2022, 07:29 PM
Targa_PB_78_SC
From your photos, looks like you went through the effort to remove those metal clips from the electrical plugs. Those plugs just pull off with the clips in place, maybe next time. Make darn sure you have all the clips and none went into the intake. They are magnetic and can be fished out. In fact, it might be wise to run a magnet in all the intakes for a good check.
BareRearedRookie
Old 12-04-2022, 04:55 AM
I know it would have been easier to drop the engine to do this but I have a one car garage and live here in Montreal were the weather doesn't permit working outside in January. Got all the clips but broke the O2 sensor plug. It was already kind of loose. How hard is it to find that part?
Old 12-04-2022, 05:08 AM
Congratulations Joe!
When you get ready to start the car back up, you’ll need to set it back to factory baselines as likely things were adjusted to make it run with various vacuum leaks and other problems.
If you can’t find the procedures, let us know and either I or someone else can get you the settings.
Rutager West
Old 12-04-2022, 09:27 AM
[QUOTE= How hard is it to find that part?[/QUOTE]
Good luck, but I have seen on this forum where a member is making a nice replacement.
Old 12-04-2022, 10:17 AM
Thanks I'm sure I'll have a lot of questions.
How do I remove the injector caps? Do I need a special tool?
Old 12-04-2022, 11:13 AM
Trying to remove the oil cooler cover from the top, there are four bolts on top but the cover won't come off, is there any other bolts below to remove?
Old 12-12-2022, 05:28 PM
ADDvanced's Avatar
They're staked in place. Dremel w drum cylinder.
You should probably watch some of my videos on CIS refresh:
Teardown:
Go to 6:40 to remove the injector seats
Also, make SURE you rebuild your airbox, I'm guessing the factory screws holding it together are pulled out, I used nuts/bolts on mine instead to compress it together. Airbox rebuilding video:
This is reassembly of everything, how to mount new injector seats, plug the EGR port on the bottom of the intake, bunch of details this should help as well
Sorry for spamming my channel but I think this will really help you out, Joe. Cheers!
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 12-12-2022, 05:46 PM
I have watched your videos several times now and have found them very useful.
I'm referring to the grey plastic cover that you can see in the last photo of the engine bay I posted.
I think there's 2 from below that also hold the engine tin.
Old 12-12-2022, 06:20 PM
Yep, there are two bolts on the rear face of the engine that hold the engine tin and the cover to the back side of the head. You should be able to reach them from underneath.
1982 911SC
Old 12-13-2022, 08:33 AM
I did have a look and there are 2 bolt, thanks.
Old 12-13-2022, 08:58 AM
