Triangle of death done
Old 12-21-2022, 01:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
Targa_PB_78_SC
mike sampsel's Avatar
You might want to coat the oil light sender in JB weld
BareRearedRookie
Old 12-21-2022, 01:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
What type of JB weld, around the brown area?
Old 12-21-2022, 03:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
Targa_PB_78_SC
Right, circle to cover around the plastic area which can crack and leak. I use the black-and-white-two-tube stuff, (the original) good to 500 degrees I think their strongest. You might need another washer if you remove your sender to coat it good.
BareRearedRookie
Old 12-22-2022, 04:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
Steve F's Avatar
Thumbs up
I wrapped blue tape around the hex portion and then filled it in with JB Weld. Peeled the tape off later and it looked really nice after:<)
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 12-22-2022, 04:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
na2ub's Avatar
Where does the other end of the vacuum hose, that goes down into the rear crossmember (in the pictures above) go? I removed a bunch of stuff, including CIS, and that hose was disconnected. I pulled it out of the hole in the crossmember to find it just dead-ends, and is attached to nothing.
Thanks in advance.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 12-26-2022, 11:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
Schulisco's Avatar
One of the oil tank breather lines goes from the crankcase breather plate to the oil tank. The another one goes to the rubber intake boot.
https://bit.ly/3FVeQlm
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 12-27-2022, 05:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
Here's my CIS ready to go in. I left runners 1 and 4 for easier access to some bolts.
Old 12-27-2022, 07:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
na2ub's Avatar
This one. Mine was also cable tied. When i removed the tie and pulled it just came out of the crossmember. I assumed it was an old hack, until i saw it here.
Doug
Old 12-27-2022, 07:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
I can have a look on under my car to see if I can see were it terminates
Old 12-27-2022, 08:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
na2ub's Avatar
If yours is like mine, it terminates about 4" into that crossmember, to nothing. Question is, where does the other end of the hose go. Cruise control?
Doug
Old 12-27-2022, 08:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
Can I change the upper valve gasket without draining the oil?
Maybe easier without the CIS
Old 12-28-2022, 12:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
If memory serves, that’s exactly what it is, the atmosphere air end to the cruise control.
Rutager West
Old 12-28-2022, 01:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
stevie 77 930's Avatar
Yes, all of the oil drains to the bottom of the engine, and you might even want to adjust the intake valves while you're at it.
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 12-29-2022, 03:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
Another “while you have it out”. My engine is back in the car after being on the engine stand all of 2021. Last weekend I decided I needed to finally verify my CSV was in fact spraying fuel out of it.
In the year the motor was on the stand I removed it to put in new O rings but never tested for spray function. Anyway doing it with the CIS back in the car is not fun. Took me an hour and a half to remove it and probably 4 hours to reinstall using lights and mirrors. With the CIS on the bench it would take only a few minutes. I would never do it in situ again. Also check to see that you have the correct mounting flange. There are threads with pictures that show the difference between flanges.
Old 12-30-2022, 08:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
PCA Member since 1988
I think I mentioned this awhile back, but I'll say it again since you're almost done. Consider removing the idle air valve and decel valve and associated plumbing. Without that stuff in the way, you can reach the parts in the TOD much more easily. When I reinstalled my rebuilt engine a year ago, I forgot to fully tighten the oil pressure switch. Of course, I had a seep of oil down the top of the engine, etc. I was able to easily put a mirror back there, see that it was coming from the switch, and then remove it, check it, reinstall it, and tighten it, WITHOUT futzing with the CIS. Now, my 1973.5 car has a hand throttle, so I can just set that for a few minutes to let the engine warm up. Otherwise, you have to keep your foot on the gas to hold the RPM up for a minute or two, or start driving it immediately. IMO, it's worth the tradeoff.
Old 01-05-2023, 11:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
Everything is back in now, had a fuel leak from the cold start valve but all tighten up now and no leaks.
Old 01-05-2023, 11:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
So I tried to start the car, I haven't received the fuel pressure tester I ordered yet and was a bit inpatient. I also put in new plugs wires cap and rotor. I think I installed the plug wires in the right position on the cap. When I start the car the car rpm surges and back fires and shuts down.
I know I should check the fuel pressure before but could my wires be in the wrong position?
Is there any adjustments to the throttle position micro switch which needs to be adjusted?
Old 01-06-2023, 01:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
Targa_PB_78_SC
You can check your wires via firing order, rotating CCW from number 1 wire. Once the order is verified, number one is at the notch on the dizzy. Or around 3 o’clock.
Sometimes sputter and BF can occur until the lines get all primed.
Old 01-07-2023, 06:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
Targa_PB_78_SC
After wires verified, I’ve primed by (air cleaner off) lift the CIS plunger slightly with key on, as soon as you hear fuel squirting in the injectors let go of plate plunger.
Wetting down the cylinders with gas not great. If your car has sat a long time you might crank a while to get oil pressure. You should pull the CDS plug to do this. Although I’ve done it with the fuel pump relay out.
Old 01-07-2023, 06:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
