Securing down floor mats for 930
Hi folks,
I can’t seem to make any forward progress on finding the correct part to secure some floor mats down on my 86’ 930. I am unable to verify which manufacture it is but I have contacted both Lloyds and Pelican, sent them pics but everyone is stumped. Pics of the floor mat’s underside shows a buckle type connection. ![]() Sent from my iPhone using Tapatalk |
Modification by the previous owner? The mats that came with mine were bunched up really bad, a safety hazard, really. I ended up taking mine out. A clip at the back, like you show, and a clip at the front could have helped hold things in place.
Worst case, you could buy a clip set and some strap/webbing and sew on some new ones. |
The mats themselves don’t look to be modified, I’d like to avoid modifying them if at all possible and just find the pieces that the buckle would connect to. Sent from my iPhone using Tapatalk |
My 81 930 floor mats don’t have any buckles
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
Driver
My '87 floormats have that buckle. Hooks up to a matching one under the seat.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Banned
I had a set of floor mats that had a clip like that on the mat, and a clip insert with webbing binder clipped to a little flap under the driver's seat. They were from Lloyd's.
COL911
Lloyd’s sold a kit with clips and straps that used the clip on the mat shown to affix to the seat rails. I sold a kit to a fellow pelican awhile ago and will try to find and post pix so you can at least know what to search for. You may also be able to buy strap and clips to fit your mat at camping store then make a similar clip for seat rail.
COL911
Ah thanks but those Lloyd buckles don’t look like it would work with the buckles that are on my floor mats. Sent from my iPhone using Tapatalk |
Two words. Zip Ties
Get CoCo Mats...perfect fit and no sliding
Rey....77 930 "the Mistress" |
Thx for the pics. I have a set of those too. Doesn’t work with my floor mats
I used Black button snaps for the carpet including the tunnel/shifter link box. easier to do service that way.
My Turbo mats have a hump on the rear side that hold them in place
Driver
My mats have those plastic clips, too. They connect to straps that run under the seat and hook onto the seat rails.
Driver's seat side, floormats in the footwell, as I'm sure you know... ![]() ![]() Then the straps run under the seat to these little metal clips which hook onto the seat rails (as seen from the back seat)...
I have the same system in mine. The mats slew around sideways when I get out of the car. I ran the strap down the center of the square channel to minimize lateral movement and attached the hook in the same place. It didn't help much. The mats only seem to be designed to stay in place in case of a frontal collision. ![]() Does anyone have floor mats that stay in place? BTW the clips on my mats don't match the clips on the end of the strap, so I connected them with heavy duty zip ties.
My '84 Carrera had Lloyd's floor mats in it when I purchased it this past August. The straps look like they could be the same ones you have. Sounds like Lloyd's are now using a strap with a redesigned buckle? Unfortunately, I have no idea how old these are.
