Summit to the rescue! Thank you!
^ Awesome!
We're sending a pair of these new third-generation seals to Jeff Alton at Turn3 Autosport in Langley, BC for his review. |
Success! I tried the "OEM" one from our host and returned it... Waited and got this URO one and what a difference!
Rubber was more compliant and the little extra flap width easily covers the corners now. Thanks URO for keeping us informed about availability and making this great part. Karl |
Mark |
Karl |
Looks like Summit is out of stock now as well, until late December.
To anyone who just installed a new seal from this batch (code 11104 on bottom right corner of label), please share your feedback ASAP. If there are any adjustments that should to be made, we'd love to do it before we schedule the next production run. Thanks! |
Installed mine and had better luck than with any other seal I've used!! Seems of good quality and the fit looks great to me. Only variable in my install is I use a rubber "rope" instead of the metal trim so I'm sure the fit is a bit different. And of course I forgot to snap a better finished install, but I am more than happy with fit.
Chinese glass is being used http://forums.pelicanparts.com/uploa...1724689155.jpg http://forums.pelicanparts.com/uploa...1724689155.jpg http://forums.pelicanparts.com/uploa...1724689155.jpg |
Excellent, how is the inner lip / headliner coverage?
[QUOTE=Queefchief;12309346]Installed mine and had better luck than with any other seal I've used!! Seems of good quality and the fit looks great to me. Only variable in my install is I use a rubber "rope" instead of the metal trim so I'm sure the fit is a bit different. And of course I forgot to snap a better finished install, but I am more than happy with fit.
Chinese glass is being used http://forums.pelicanparts.com/uploa...1724689155.jpg Where did you get the "rubber rope"? thanks |
[QUOTE=trials935;12309392]
Is this new seal available in the UK yet?
Does this seal work for the 996 as well?
Does our host pelican have the latest version Uro windshield seal for a 1988 911 in yet? What about the rear seal?
We're completely out of stock for Rear Window Seal 911 545 225 00 for coupes, and are currently redesigning this seal to improve fit in the corners. The updated seal probably won't be available until sometime in 2025, so you may want to go with an alternative in the meantime. |
new seal
I just ordered one from rock auto, they carry them, sorry pelican..... (911.541.225.03)
get them while you can. SmileWavy |
| All times are GMT -8. The time now is 10:10 PM. |
