SC oil temperature
Hi Everyone, How hot should the reading on the oil temperature gauge be typically on a hot sunny day in the 90's? Out for a 1/2 hour drive in some stop and go traffic I was becoming concerned with the slow creep towards the red zone. Here is a picture at the end of my jaunt. Where is your readings on a similar day? Thanks
Old 05-18-2017, 04:33 AM
The markings on my Sc are different than yours. I have a black box outlined by a white line at the bottom. But mine never goes past the 9 o'clock position. Hell, it's barely gets out of the black box on hot days. Yours may be running hot and mine may be running cool. Somebody with more knowledge (and that would be just about anybody on here) I'm sure will chime in with an answer.
JUAN
'80SC Targa
Old 05-18-2017, 05:46 AM
Send a message via Skype™ to kyngfish
Depends on what you mean by stop and go traffic. My car runs great in south Florida. On days when it's 80 or 90, normal driving with a few stop lights barely takes it past the first hash in 45 minutes of driving. I have the normal Carrera cooler with no fan.
What you're showing there happens to me on 95+ degree days when I'm in some bumper to bumper traffic for extended periods. Like 20 minutes or more of creeper gear speeds.
Smarter guys can chime in here but I believe your gauge should be just a little above that first hash on summer days in normal driving. If you're pretty steady there then what you're looking at has more to do with stop and go traffic. If you're getting those temps while moving through traffic at a normal to moderate pace, meaning every few minutes or so you're cruising at 35 mph or higher. Then I would start troubleshooting flow to the front cooler.
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250
Old 05-18-2017, 05:53 AM
1988 Carrera
shadowjack1's Avatar
Just so you know. If you look under lip on the left hand side of the gauge, you can see the temp in degrees F. It's hard to see, you have to get your head at a very steep angle behind the wheel.
88' Carrera
79' SC gone (lost to Katrina)
75' Targa gone
72'914 gone
72' 914 gone too
Old 05-18-2017, 06:16 AM
mark waller's Avatar
Send a message via AIM to mark waller
I live in Southern California and my 83 SC runs around there on a hot day or slow driving. I did add a brass 28 row cooler instead of the trombone stock cooler. Usual driving it sits in the middle of the gauge to up to where your picture shows.
Mark
1983 911SC Cabriolet - Platinum Metallic
1971 911T - sold and now in Paris
1969 912 - sold
Old 05-18-2017, 06:46 AM
Bill Verburg's Avatar
You have a 'B' gauge face showing just under 250F, IMO uncomfortably hot
The faces can be changed to the numeric type by N Hollywood or other similar outfits
Bill Verburg
Old 05-18-2017, 06:48 AM
bump
Old 05-18-2017, 06:53 AM
Thanks Mark Waller mine's an 83 as well
Old 05-18-2017, 06:59 AM
Actually, the numbers shown there are degrees Centigrade. BIG difference.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 05-18-2017, 07:06 AM
1988 Carrera
Uwanna:
You are right, sorry I just forgot.
88' Carrera
75' Targa gone
72'914 gone
72' 914 gone too
Old 05-18-2017, 07:39 AM
Eng-o-neer
Tremelune's Avatar
The two ticks in the "B" gauge go from 194°F to 248°F. 180-210°F is your happy place.
The perfect running temp
Elephant Racing | Tech Topic | Oil Temperature and Engine Life
It's worth noting that Elephant makes good money selling oil coolers, but they are also a group that knows what they're talking about. Some engine sections are hotter than others...some gauges are more accurate than others, it's good to boil water off at 212°F, etc...
If it were me, I'd first make sure my thermostat was working well, and then install a Carrera oil cooler with a fan...Or just make sure I don't go near traffic on a hot day. All that said, your motor won't explode from driving while a bit hot. Sometimes it can't be avoided.
Old 05-18-2017, 08:23 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Our '86 runs at 180-210.
We installed a 210F oil cooler fan thermostat.
210F-Fan on.
195F-Fan off.
On highway drives to Palm Springs @ 100F our oil temp will activate the fan
keeping the oil at 210-220F.
Factory recommendations on 3.2 oil temps is 180F-210F.
210F to boil off any moisture in the oil.
We use Mobil 1 15-50.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-18-2017, 08:40 AM
Here in Tampa Florida it gets very hot! When I first got my 1982 SC the temp was about where yours shows on hot days. I replaced the trombone cooler with a Carrera cooler and a fan. This brought the temps down to just a bit above the first mark under the same outside air temps - perhaps 20 - 25 degrees.
Old 05-18-2017, 08:50 AM
Thanks guys
Old 05-18-2017, 09:26 AM
evan9eleven's Avatar
I have a style C gauge in my '81. Needle moves max 3 - 4mm from dead cold to fully hot, I've never seen it go any higher then even with the top edge of the black box. Kinda useless. Is this normal for this version of the gauge?
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 05-18-2017, 01:31 PM
Eng-o-neer
Tremelune's Avatar
That seems normal—the working range of that gauge is near-useless.
I don't think you can just change the gauge, though—you have to change the sender in tandem or the reading will be inaccurate.
Old 05-18-2017, 01:35 PM
Good to know that its normal anyway. The range of movement is so bad that the PO didn't even know that the sender was shot when he sold me the car. When I re-do my gauges next winter I'll get it recalibrated and replace the sender (again.)
2004 Boxster S
Old 05-18-2017, 01:41 PM
Fleabit peanut monkey
Bob Kontak's Avatar
+1 Just above the box when 'hot". I have a Turbotrol (sp?) oil cooler, though. I can push it to just under 9:00 is I beat on it.
Hook, What do you have in the passenger front corner? Did the factory still stick with the trombone through 83?
1981 911SC Targa
Old 05-18-2017, 01:58 PM
Bump
Old 05-19-2017, 06:48 AM
The gauge faces can be changed as long as you stay w/ the same style
A => A
B => B
C => C
The sender needs to match the gauge style, whatever face in on it
Bill Verburg
Old 05-19-2017, 07:45 AM
