Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
JE wrist pin clips
I'm pretty sure I've read stories on how difficult it is to install JE clips and now I can add mine. Having worked on motorcycles for quite a few years, I've probably installed many hundreds of clips but nothing compares to how stiff the JE ones are. Even doing it on the bench was not fun, no way will it happen installing the second one with the cylinder studs in the way.
Has anyone used the Stomski pin tool to install them? How well did it work? Anyone have a 23 mm one they will loan or rent or sell to me? Thanks
1986 Targa Guards Red
2021 MT09 SP
Old 01-18-2018, 11:34 AM
tool
That tool is very good, both 22 and 23 are sweet, watch his video and stop the bleeding !
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 01-18-2018, 11:37 AM
enzo1's Avatar
76' 911s Signature Edition
Old 01-18-2018, 11:55 AM
KTL KTL is online now
Schleprock
KTL's Avatar
I completely defer to Mike Bruns on using the Stomski tool since he's built more engines than most, and sweats the smallest of details. Reason I say that isn't just to pat Mike on the back, even though he deserves one for his professional advice he's always very willing to share with us average Joes.
I say that because some claim the JE wire locks can get stressed by the compression of the clip into the tool.
JE Wire Locks – A Cautionary Tale
I find that claim a bit hard to believe because you MUST compress the wire clips in order to force it into the receiving groove. Note that I posted some links from Mahle in the above link. It's become common knowledge that the Mahle clips are easier to compress than the JE clips and therefore Mahle's tips/tricks are easier to accomplish with "softer" clips
Kevin L
'86 Carrera "Larry"
Old 01-18-2018, 12:17 PM
tool
Thanks Kevin, I install the clips half in/out at an angle as to not stress any more than needed, be sure to have your glasses on and point it away, the exposed open end of the clip finds the groove and push in like a syringe and its home, I like to detail the sharp ends of them as well as oil up the bore of the tool. The Je's are heavy compared to most anything else out there, if you look at them installed the chamfer on the pin to clip makes a more complete groove, if you notice on most the pins pound on the clips and hurt the grooves if they have the room to move.
Have Fun, Mike Bruns
Old 01-18-2018, 12:34 PM
Thanks for your input Mike and Kevin. Oh boy, Mike M's engine failure is the stuff of nightmares for weeks to come. Even greater care will go into installing clips with the Stomski tool.
2021 MT09 SP
Old 01-18-2018, 01:33 PM
Schleprock
KTL's Avatar
Since scary movies are the "in" thing nowadays, add my engine fail to your nightmares for the rest of the month?
Engine Bearing Failure- Disassemble Heads Too?
Not trying to make a pissing contest out of this. Mike Metzler's fail was worse than mine because major engine components came apart. My fail just hosed all the bearings.
Kevin L
'86 Carrera "Larry"
Old 01-18-2018, 01:52 PM
Under the radar
Trackrash's Avatar
Those clips are a PITA for sure. I bent one and had another go MIA across the shop before giving up and making a tool.
I used a thin piece of wood to hold the back of the piston steady. I ended up making my own tool, although mine were the 22mm pins.
All you need is a bolt that will fit nicely inside the piston pin and a pipe or tube that has an ID just a hair smaller in diameter than the hole in the piston. Machine off the head of the bolt so that it fits inside the tube and you are set.
I use the ratchet extension to push the clip in place.
Gordon
'71 911 Coupe 3,0L outlawed
Old 01-18-2018, 03:51 PM
arbita1's Avatar
Here’s my version of the tool.
Use a small hammer to tap the end of the extension to seat the ring. It was horrible getting those in.
Matt.
83 911SC
85.5 944 NA - Sold
Old 01-18-2018, 04:33 PM
Kevin, oh such a sad sight your failure was. After disasters like that, ones wish for that mythical time machine so you could just go back and do it differently.
Gordon and Matt thanks for chiming in. I understand what you have explained and I can see that doing the job too. Best part is, I can give it a try on the bench using the old clips to get a feel for it.
2021 MT09 SP
Old 01-18-2018, 04:42 PM
Love my Stomski tool. You can do the 22s by hand/fingers, but the 23s are near impossible.
206 637 4071
Old 01-18-2018, 04:59 PM
There aren't enough cuss words in the English language to accurately describe my feelings towards those clips...
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 01-18-2018, 05:09 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1
I did mine by hand when I broke the Porsche Tool which is similar to the Stomski Tool.
Practice off the block and you will see, not a big deal at all, small screw driver to hold in place then walk it in, Voila!
Big CAUTION, stuff the holes with rags/tin foil as not to drop a clip in the block. Ask me how I know I got real lucky and was able to fish it out blind with a magnet.
'85 Carrera Targa
PCA/POC
Old 01-18-2018, 05:27 PM
Ken911's Avatar
I always use the small screw driver/bloody fingers method. the stromski tool is for the thinner stock clips I thought.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 01-19-2018, 06:04 AM
Jeff Alton's Avatar
I'm with Mike. Years ago I put a modified screw driver through my hand installing one of these, still have the scar. Picture my be archived in the engine building forum... Use the stomski tool on every aircooled motor we build now (stock, JE or CP). The factory M96/97 and 9A1 tools we have function in the same fashion.
www.turn3autosport.com
Old 01-19-2018, 09:49 PM
(man/dude)
Jonny042's Avatar
What is the hot setup for removing the clips upon dissassembly? I used the "normal" method but feel I was gouging the pin bores in the pistons to an unnecessary degree, and they will require some time consuming cleanup/de-burring.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 01-20-2018, 06:09 AM
al lkosmal's Avatar
Stomski tool is the one I use. Excellent tool.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 01-20-2018, 06:23 AM
The 9 Store
regards,
al
Stephen stops by the shop often. I think we have every tool he makes. Great stuff!
All used parts sold as is.
Old 01-20-2018, 07:06 AM
Found this video from Mahle. They show a variety of techniques, granted for the much kinder Mahle clips. Of real interest, check out the cool installation tool at 4:37 . I just might try making one of them and give it try. Luckily I have time to play around, lots of snow on the ground for a while yet.
https://www.youtube.com/watch?v=3kdhGBCpuxM
2021 MT09 SP
Old 01-22-2018, 05:36 PM
Never saw a reply to this post - lots of info on the installation, but can't find anything on the best way to remove the pins should that become necessary
Old 12-01-2022, 07:07 AM
