He was happy for me to hang around and assist with the usual checks which was great. Two hours later, he was done. Perfect tune at all RPM stages. Super smooth idle and making power right through to 6100 RPM. Falls away badly after that as it has CIS cams and pistons but still made 207HP at the wheels on a rolling dyno - he didn’t have the correct adapters for the 911 wheel PCD to use the hub dyno. EFI is just so adaptable, with the right guy/tuner it can be just as smooth as CIS and produce way more power. My advice is go with EFI and find a good tuner that knows his stuff. There are plenty around, if they can tune a 2JZ with 1100 reliable HP they can tune an air cooled Porsche. Last edited by OSC911; 12-09-2022 at 03:48 PM.. |
Do you recall what AFR or Lambda he was targeting when doing your full throttle runs?
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Longtime Member
removed CIS from 2 3.oL motors i built. had 46mm pmo's on the red, 78SC spec911 car with euro compression pistons and a recurved dizzy with SSI's I cut the heater boxes off of...
the white one was a hotrod 75 I built much like the race motor but with a very nice set of 40mm webers. ![]() i liked carbs on my flat six.... you gotta dick with them from time to time with today's pump gas offerings with all the additives, but if you are committed to learning them it's pretty rewarding. or do an EFI set up that must be thousands now days. I do jeeps now.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Longtime Member
oh ya, if you are gunna do it have somebody in the know recurve the dizzy or it won't run right through all the ranges.
I let him do his thing in the car but I was watching the monitor and the remote AFR gauge and from memory it seemed to be between 13.0 to 13.9. When it cam back after each run it dropped to 11.0 for a minute for some reason and then stabilised to around 14 or so. We couldn’t really work out why though. It pulls super hard with great low end torque but runs out of steam pretty early. Now I’m keen for pistons and cams but that’s a way off. |
Sorry... Late to the Discussion
I'm the dude reading your original post, skipping past pages of replies that were incredibly insightful and relevant - to add my thoughts, as a guy who went to carbs and did it because I needed to.
CIS is hard to beat - my OEM system went 190k miles, with a distributor rebuild being the only needed fix for fuel / ignition related repair. Don't give another thought without realist thinking of what a replacement / alternative offers... Love my PMO's, but went in with the commitment to embrace and re-kindle the old school tech. I've bridged old & new on my journey, and determined that - its hard to fail with advice of this Pelican community's guidance & input. Take it all in and do what appeals to you - you have a huge Pelican community itching to help. -- Gordo
Don "Gordo" Gordon '83 911SC Targa |
My recent EFI install
![]() Old school look with some modern tech. |
Don
I have a new set of PMO 40s on my '77 2.7L. Can someone explain the hand brake throttle knob? What is needed? How is it installed? Pics?
What are some good resources to learn how to adjust/care for PMOs? Thanks! |
Still here
If you’re not concerned about gas mileage or having stock look, I would go for PMO (assuming you’re not interested in fuel injection). Much better throttle response and sound. If I were doing it, I would get custom CPs with good valve clearance and go for a cam with more duration like GE40 or even GE60 depending on what you want to do. For that cam I like the 46s.
I’d keep the CIS if you ever want to bring back to stock. |
Thread Tools | |
Rate This Thread | |
