Need help identifying connector in engine bay - 1989 3.2
Installing my engine after a full rebuild - took some time because of supply chain issues. There is what looks to be a 3-wire O2 sensor connector by the oil filter. I can't figure out what this is for and my memory fails me. Any ideas?
![]() TIA
'87 911 GP White "casper" '79 930 Copper Brown Metallic "beast" '93 968 Amazon Green Met "moby" '97 Esprit V8 "flat eric" '97 993 Speed Yellow "tbd" |
Looks like the CIS test connector on a 911SC to measure the Frequency Valve Duty Cycle. But your car should not have that.
isn`t this one for 964 oil level sending unit?
the connector ob OP pic above could be for the 3rd brake light...what are the colors on the showing wires black and green? on of them? Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
yup ,all possible..is your cabrio and so you have the 3rd br. light..?
Ivan Ivan
Nope. It's a coupe with the 3rd brake light high up on the rear window. This car did have a whale tail on it at one time. I'm suspecting Porsche just left the connector in there from the 1987 year with the ET 3rd brake light. If I discover something I'll post here. Thank you all.
It's the connector for the decklid mounted engine light wiring loom.
-Todd
1989 911 Targa |
Awesome. Thank you. Yes that light is missing. Now I know where a new one will plug into.
