'73 911 T Targa
Substitute M10 10.3 button head for M10 8.8 hex head?
I’m redoing fuel lines and replacing my pump with a pump up forward.
The fuel line route with the most fluid path is through the bracket for the cross member. As you can see in the picture, the hose could end up rubbing on the bolt head that’s holding the cross member.
A button head socket head bolt would eliminate the sharp corners of the bolt head. It appears that M10 10.3 button head cap screws are readily available. Can I safely replace the M10 8.8 bolt with an M10 10.3 button head?
Old 12-23-2022, 12:44 PM
HarryD's Avatar
No picture!
Other than esthetics I doubt it matters.
But it will infuriate the P gods and most likely they will cause the car to self destruct.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-23-2022, 12:52 PM
'73 911 T Targa
Here’s the picture.
Old 12-23-2022, 01:33 PM
I doubt id even worry about that.
1976 914
1986 951
Old 12-23-2022, 01:39 PM
HarryD's Avatar
Why not run the hose outside of the clamp? Zip tie into place.
Harry
2020 MB E350 4Matic
Old 12-23-2022, 01:50 PM
It's a 914 ...
stownsen914's Avatar
Not sure I'd worry about rubbing on a bolt like that, but if concerned, I agree a zip tie would fix that.
Old 12-23-2022, 02:11 PM
H-viken's Avatar
Shouldn’t be an issue switching the bolts as you mentioned
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 12-23-2022, 09:48 PM
PCA Member since 1988
Put an Adel clamp under that bolt and then run the hose through the clamp. That will keep it from rubbing on the bolt head or anything nearby. And it will look like the factory intended to do it that way.
Old 12-23-2022, 10:48 PM
'73 911 T Targa
The button head bolt leaves no sharp corners. I like the idea of adding a clamp. I’ll add that too.
Old 12-24-2022, 12:25 PM
moparrob's Avatar
Harbor Freight is your friend
https://www.harborfreight.com/media/catalog/product/cache/9fc4a8332f9638515cd199dd0f9238da/i/m/image_20102.jpg
Old 12-26-2022, 11:32 AM
