gumba's Avatar
paint stripping alternator fan
What's the best way to strip paint off a mag alternator fan?
thanks.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 09-07-2015, 12:13 PM
patz's Avatar
Soft media blasting or chemical like Strypeze.
I will use a FAF when I am dying of thirst
Old 09-07-2015, 02:11 PM
Kleen strip "stripper" comes in a spray can from Home Depot.. I would test a small area first...Not sure what it does to the Mag but that stuff works wonders on everything else
Scott
1979 930 - Black on Black and in the woods
"My third child that will cost more in the long run" :shock:
Old 09-07-2015, 02:27 PM
I wouldn't use any chemicals on the mag, just media blast, not too aggressive.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 09-07-2015, 03:34 PM
non-whiner
mreid's Avatar
Citristrip. Does an amazing job and won't hurt the metal.
"Too much is just enough."
Old 09-07-2015, 07:30 PM
This is what I use.
Chris
'75 911s Targa
Old 09-07-2015, 07:39 PM
Bill Douglas's Avatar
Be careful if you do the media blasting. I wouldn't The metal is as soft as s, really soft I mean.
Old 09-07-2015, 10:44 PM
gumba's Avatar
I'm going with the citristrip.
Harold
Old 09-07-2015, 11:19 PM
theiceman's Avatar
was it just painted or powdercoated ?
powder coating is tough.
update us on your progress.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 09-08-2015, 04:30 AM
E Sully's Avatar
I had no problems using aircarft stripper on a powder coated mag fan. First coat got off majority, second coat most of the rest. Then a clean up with glass bead in the cabinet.
Ed
1973.5 T
Old 09-08-2015, 06:32 AM
Chain fence eating turbo
If paint, Tal-Strip is good. Never brush it on. Pour it on, and it will only take one coat.
Lesson I learned stripping cars at my dads resto shop.
If powdercoat, media blasting will be required unless there's something out there that takes off powdercoat chemically.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 09-08-2015, 06:48 AM
gumba's Avatar
I painted the fan a few months back using VHT primer that was suppose to adhere to magnesium. Then PPG primer & paint to match the car color. I have about an hour run time on the motor.
I'll strip it with the Citristrip mentioned above and see how it looks.
Harold
Old 09-08-2015, 06:53 AM
Senior Member
Jdub's Avatar
Once cleaned and painted they look great but never seem to stay that way for long.
The air intake brings in all sorts of particulate at speed, blasting your nice work. My SC fan supports pollishing, so that is what I do and otherwise do not attempt to cover it (clear or paint).
'78 Targa in Minerva Blue
Old 09-08-2015, 07:41 AM
fallingat120mph's Avatar
Old thread I know - but since 2015 has this chemical been used by others? Is it safe for paint removal?
Previous owner painted and aside from it looking horrible is starting to chip away.
Just curious what others have done in the last few years that works and does the least damage to the fan/housing. I have the engine apart and trying to clean this fan blade up before I put everything back together.
****edit: car has 200,000 miles on it and gets driven a lot so not worried about show car quality. just want this red paint off.
Thanks!
1986 911 Coupe
1986 911 Targa
Old 01-09-2023, 02:53 PM
I had my fan and housing cleaned and cerakoted by Shawn at Trusix - and it's beautiful. I'm hoping the cerakote will last longer than other coatings
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 01-09-2023, 10:48 PM
Banned
Cerakote will last the longest and give you the thinnest most durable finish.
Old 01-10-2023, 05:32 AM
