Installing AC Trinary Switch - help identifying plug
All,
Just getting through a project, part of which is installing a trinary switch into my AC system. I won't get into all the details, but this switch (from an Isuzu believe it or not), is the best combination for the mechanical and electrical install, but I can't find out where to get a plug that will fit it. I had thought it was a standard Bosch plug, but so far no luck....so hoping that one of you can identify it. Thanks for any help you might give... D, |
..oops, here is the pic
![]() D. |
Can’t help you with the exact part search, but I used this kit from Vintage Air with great success with my previous LS swap Miata project.
https://www.summitracing.com/parts/vta-24678-vus?rrec=true |
Yup, saw that one, but the configuration doesn't allow it to fit....I am fitting a 964 AC system into an earlier car, so the need is quite specific unfortunately...hence the switch I got.
Thanks though! D. |
Could you show a side pic of the connector?
Also you may want to try this website or contact them with a couple of pics. |
I think I found it, it is a VW/Audi part p/n 357 919 754, our host sells the plastic housing but not the female pins.
Local VW dealer sells the pins - $25 EACH - so $100 for the 4 I need. I am looking for alternatives, seems like there are some online, so hopefully I can buy a complete plug/pins. Just need to find the Schraeder valve that it threads on to, may just head to a wrecker and look for the appropriate VW/Audi and take it off. ![]() D. |
Why not buy the whole thing from eBay -
If you don't want to use the wires that come with it, I'd pull the pins out, measure them, and get the equivalent pin size from Digi-key. $25/pin is flat out highway robbery.
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
Original Owner
I put my HI/LO trinary pressure switch from Vintage Air in the refrigerant line at the back of the compartment right below the fans. There a lot of line to work with so it can go most anywhere that you can run the harness to your relay, fans and compressor.
![]() This was the test setup and I've now fastened the line a bit lower on the rear wall and out of sight.
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
If you can (and have them in Holland), make a trip to your local auto wrecker and stroll around in the yard. I'm guessing you will find any number of possibilities.
1986 Targa Guards Red 2021 MT09 SP |
Hey guys, thanks for all the responses....I am following up on your ideas.
1. Heading to a wrecker to see if I can get the whole thing off of a wreck. 2. I found an Alibaba item that will sell me the plug and the pins for like $10 each, but long delivery time, so hopefully ide No. 1 pays off. 3. Because it's a 964 AC system fitted to an early '89 chassis, the best location for the trinary switch is actually in the front DS fender as part of the receiver/dryer assembly. I am going to see if I can machine the dryer assembly to take a standards schraeder valve as an option. Thanks again! D. |
https://www.skoda-parts.com/spare-part/357919754-4-pin-terminal-block-skoda-29539.html You obviously need the part # for the pins; PET (yes, VW/Audi also use PET) usually lists these towards the back. But the Skoda web site helpfully says you'll be needing these terminals for @ 0.51 Euro each, which seems about right: https://www.skoda-parts.com/spare-part/6u0972505a-terminal-pin-2-8mm-skoda-16642.html The connector and terminals really look like Junior Power Timer stuff to me, eg: https://www.bmotorsports.com/shop/product_info.php/products_id/1754 Quote:
https://www.amazon.com/conditioning-pressure-connector-harness-8D0959482B/dp/B08YDFF35G seems to indicate the screw-on part is a "Behr 8D0959482B Hi Pressure Switch" . Buy the genuine Behr switch on it's own: https://www.amazon.com/Behr-8D0959482B-Hi-Pressure-Switch/dp/B009HA96JA Or generics on Flea Bay from about $13 USD.
'77 S with '78 930 power and a few other things. |
