Front shock tower bushing replacement
I wonder if someone could show how to replace/press in new
rubber bushing in the front shock tower?
Picture borrowed from another thread.
Cheers
Old 01-07-2023, 08:07 AM
stevie 77 930's Avatar
Best to replace the entire mount with new bushings.
https://www.pelicanparts.com/More_Info/91134101800.htm?pn=911-341-018-00-M127&SVSVSI=0577
Scrap away the molded hard sealant. Remove the 3 fasteners, washers and plates.
Then take a driver or drift and bang away from the top. The mount will drop down. Clean up your hardware and the replacement is fairly straight forward. A front end alignment will be needed after replacement.
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 01-08-2023, 07:03 AM
You can push them in and out with a hydraulic press pretty easily with some dish soap,put pressure in center they’ll pop right out.
Old 01-08-2023, 07:17 AM
If you want to do this without messing up your alignment, you can just replace the bushing and leave the mount alone. Just cut out the old rubber bushing with a box knife, and install a 2 piece bushing from Elephant Racing. A bit of a pain to cut out the old hard rubber but otherwise an easy job.
_______________
John
1988 Carrera Targa 3.2 G50 - Sold.
2017 Chevy Silverado K1500.
Old 01-08-2023, 09:06 AM
I boiled my old mounts for about 10 minutes to soften the rubber, pressed out on hydraulic press using deep well socket. Got them blasted and Cadmium plated, then pressed the rubber back in..... I believe I warmed the rubber up in the oven at 170 deg, then put a bit of silicone lube on them and pressed back in place. Old rubber was still perfect, so now the mounts look like new old stock.
"Barn find" 1986 911 turbo
Old 01-08-2023, 09:24 AM
Who sells the rubber for the mounts? i checked our Host and only saw the entire mount assembly?
Old 01-08-2023, 03:46 PM
H-viken's Avatar
Elephant racing
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 01-09-2023, 09:56 AM
famoroso's Avatar
Rebel Racing offers a two piece semi-solid version...
https://www.rsrproducts.com/product-page/rsr-semi-solid-upper-strut-mounts
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 01-09-2023, 12:34 PM
Ok thanks. I thought 1-piece mounts were available which required a press to get them inserted.
Old 01-09-2023, 02:37 PM
Thanks for input regarding this matter.
The choice has fallen on this bushing. It’s in two pieces for ease of installation.
Old 01-14-2023, 08:21 AM
