Random bolt found in engine bay...where does it go?
I found this random M6 bolt in the engine bay, any idea where it goes?
Old 01-14-2023, 09:43 PM
Could be the engine surround tin, look similar to the ones I just removed, although that washer looks thicker.
Old 01-15-2023, 01:59 AM
touringmandan's Avatar
M6? M8? M10? (I hope not!)
Old 01-15-2023, 06:02 AM
Looks oily with a thick washer. Where in the engine bay was it? What engine and intake are you running?
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 01-15-2023, 07:44 AM
Originally Posted by touringmandan View Post
m6? M8? M10? (i hope not!)
m6
Old 01-15-2023, 09:52 AM
I have a completely stock 3.2
The bolt was in the back left (drivers side) sitting on the engine tin
Old 01-15-2023, 09:53 AM
na2ub's Avatar
Top of the case, where the SSIs tabs mount to? I believe those are M6, and there should be 2, one on either side of the case split, in the rear.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 01-15-2023, 10:00 AM
Mark Salvetti's Avatar
I think those hold the engine shroud in place. Or the duct that directs air to the engine-mounted oil cooler.
Mark
1979 911SC Targa
Old 01-15-2023, 12:09 PM
lateapex911's Avatar
Mark
Maybe the shroud, but not the duct, if he found it drivers (left) on the tin.
Looks oily. Washer looks thick. is the engine clean? oily?
The shroud is (on mine at least, a 2.7) held on with plated M6s with garden variety plated washers.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 01-15-2023, 12:35 PM
Pic of my shroud bolts
Old 01-15-2023, 12:39 PM
Engine is clean, not sure how this got so oily.
I'll search for where this goes next weekend.
Thanks all for the suggestions!
Old 01-15-2023, 05:33 PM
Just look at the engine sheet metal. I bet you will find a hole where that goes close to the edge of the engine sheet metal where pieces are joined together.
Like the one in the center of the image and just to that one's right mostly hidden by the heater blower tube. There are several used to hold the engine tin together. They can be a pain to get back in place, and tight. I use a 1/4 drive and a extra long extension, with a swivel socket.
Use a flashlight and just look around. You will find the missing one.
Old 01-16-2023, 09:27 AM
