CIS Return Lines?
I’m installing an 83 3.0 in a 79 SC and it looks like the return lines have conflicting connections. Can someone confirm that these are indeed the return lines and if so is there a part missing or do I need to replace the line from the engine? Hoping not to go the simple route of cutting the fittings and connecting the lines.
Thanks - Chris ![]()
Looking for: 1969 911T - Engine - 6196603 & Gearbox - 7196742 1969 911S - 901/13 Gearbox - 7195559 |
My 79 CIS had the male cone with nut on the engine side, which screwed on to the female cone chassis side return line. I do believe this configuration changed over the years, so you will likely need some adapter. I can't speak to the 83 CIS, but your 79 should have 3 lines that go through a metal retaining bracket on the driver front of the engine bay. 1 is fuel in, 1 is fuel return, and the big one is the brake booster vacuum line. The fuel in, should terminate in a J bend fitting that goes to the top of the accumulator.
Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo Last edited by na2ub; 01-22-2023 at 08:08 PM.. |
Missing. It?
If anyone has more info please do post. Thanks - Chris Quote:
Looking for: 1969 911T - Engine - 6196603 & Gearbox - 7196742 1969 911S - 901/13 Gearbox - 7195559 Last edited by Stophos; 01-22-2023 at 12:45 PM.. |
I went an checked (and edited my above post). On my 79, the return to tank is a FEMALE cone (M14) fitting.
Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo |
![]() na2ub- Actually this is a M14 Male cone. Male fittings have external threads while Female fittings have internal threads. Also, I sent a email reply to Stophos. Len
Thanks to all that responded and to Len who solved my issue!
