915 reverse gear install direction
915 reverse gear install direction: markings out or markings towards the gearbox?
On disassembly my markings were facing inwards, but my Bentley says markings should face outwards.
Maybe it doesn't matter since it's reverse, or maybe the prior builder knew something I don't.
Old 01-26-2023, 06:41 AM
If your concerned, install the reverse idler gears and look at the offset as witnessed by wear on small gear, and install that way.
Old 01-26-2023, 07:13 AM
kevingross's Avatar
Numbers face outward. Perhaps less critical for reverse since it doesn't get used to much and noisiness is less of a concern.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 01-26-2023, 09:26 AM
Thanks. Makes sense.
Old 01-26-2023, 10:16 AM
numbers out and the wear pattern on the pic shows the gear is in backwards
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 01-26-2023, 11:16 AM
Ian,
curious if the wear pattern on the gear teeth or on the outside face is the tell. Trying to learn as I go...
thx
Old 01-26-2023, 03:57 PM
The tooth at 10 oclock has a wear bar at the inner edge of the tooth , a dark line
If you flip the gear the dark line will be on the nut side .
Then put the other shaft in and all the bearings ans sleeve and you can see the tooth match up where the dark edge is just off the other gear .
Hope this helps
Old 01-26-2023, 05:01 PM
kevingross's Avatar
Hope this helps
That's not wear. It's an area of the tooth that does not make contact with its mate, has not been lapped and sees no practical wear. The same is true for the opposing area ("nut side"). Cheers,
Kevin
Old 01-28-2023, 01:45 PM
Analog Air Cooled
Hotshot's Avatar
When I undid my first 915 box I worked on..
86 Targa
91 964
13 6 SPD Cayenne
Old 01-28-2023, 06:38 PM
That is exactly what I am saying , lapped or any contact pattern
The visual que is what I am pointing out .
Same stuff different words
Ian
Old 01-29-2023, 04:43 AM
I'll bite: The broken idler gear teeth? Feel like I am failing some eye test...
Old 01-29-2023, 06:43 AM
Analog Air Cooled
Hotshot's Avatar
Good eye. Ya apart from all the syncros being shot, dog teeth shot, case bores spinning, the idler has a tooth chipped. Lol. That was staying put.
Old 01-29-2023, 06:51 AM
