| Registered |
				Comprehensive 1984 911 tool kit?
			Hello pelicans!  I am trying to assemble a list of all the fastener sizes and tools that would go in a specific toolkit for my 1984 911. Has anyone done this? Does anyone have a list of all the tools needed? If not, I’d like to assemble the list and post it for everyone to have! Sent from my iPhone using Tapatalk
				__________________ 1984 Hellbronze Metallic M491 | ||
|  01-27-2023, 05:44 PM |
| Registered Join Date: May 2002 Location: Portland, Oregon
			Been discussed many times.  This is the consensus.  Quote:
				__________________ Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic | ||
|  01-27-2023, 06:23 PM |
| Registered | |||
|  01-27-2023, 08:37 PM |
| Registered |
			I also have an 84 with all tools for a targa.  I'll take a picture in the morning and post it.
|  01-27-2023, 08:38 PM |
| Registered Join Date: Mar 2002 Location: Dunstable, MA
			In a small metal tool case (mini briefcase) that fits under the passenger seat: Metric socket set, 4mm up to 19mm 1/4 and 3/8 drives Multi screw driver Metric Allen set Electric fuse assorted pack Electrical tape Electrical meter 8-19 wrenches In the glove box I have Spare proper fuel pump relay Spare fuel pump hard wired unit to make fuel pump run in place of relay (been stuck and towed for this one) Up front trunk 1-4 quarts of oil , rubber gloves, funnel, rags Stock tool kit and jack. Spare tire, can of fix a flat In my pocket CC AAA membership Phone | ||
|  02-11-2023, 08:55 PM |
| Registered Join Date: Sep 2007 Location: Boston, MA
			The factory kit is nice for completeness, but if you really want to be prepared I would leave it at home and put a kit together like r_towle's.  All you need from the factory kit are the tools to change the fan belt, and maybe the battery-hold down tool.  Sunroof tool if you have one. I would add to the list: Small flashlight or headlamp Tire plug kit (instead of fix-a-flat) 12V air compressor Scissor jack (instead of the factory jack) Metric Allen sockets (I once had to refasten a CV joint by the side of the road) I manage to fit all the tools in a small plastic tool box that fits in the front trunk in that recess behind the bumper. The scissor jack is wrapped in a towel and also placed in that recess. Mark
				__________________ 1979 911SC Targa Last edited by Mark Salvetti; 02-12-2023 at 07:30 AM.. | ||
|  02-12-2023, 07:21 AM |
| PCA Member since 1988 |
			A lighter.  Just in case you need to start a fire.  While waiting for the AAA tow truck.  You could be out there awhile.
				__________________ 1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! | ||
|  02-12-2023, 06:43 PM |
| Get off my lawn! |
			One item that is basically free, and basically no additional weight but might be vital to have is: A 24 inch piece of string trimmer line. If you are trying to put gas in the car, and the gas lid release cable breaks, or comes lose, you are screwed. To open that cover with no damage at all, just thread the string trimmer line around the catch of the filler cap, and pull with both hands straight back. The lid opens. Practice a few times at home when all is well. Pop open the gas filler cap, and look at the catch. Put the string over the catch and feel the tension needed to pop it open. Close the lid, put the string trimmer line through the lid gap, and pull and see just how it works. It beats the heck out of destroying the lid or the fender getting it open to get gas to get home. I keep mine in my glove box next to the spare fuses.
				__________________ Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! | ||
|  02-13-2023, 07:51 AM |
