fallingat120mph's Avatar
Torque value for oil pressure switch and adaptor
86' Coupe/3.2
Have these now (oil pressure adapter and oil pressure switch):
https://www.pelicanparts.com/More_Info/90110117503.htm?pn=901-101-175-03-OEM
https://www.pelicanparts.com/More_Info/91160623000.htm?pn=911-606-230-00-OEM&bc=c&SVSVSI=0586
But haven't received my Bentley yet...just wanted to verify torque values...
Is it 26 for the adapter and 15 for the switch? Sounds like it's easy to over-tighten...advice/experience welcome.
Thanks in advance!
Erik
1986 911 Coupe
1986 911 Targa
Old 02-14-2023, 04:23 PM
I didn’t do the adapter but I recently did my switch and I tightened it to 11 ft lbs per recommendation of other pelicans. It felt mighty tight for its size and I wouldn’t have wanted to take it any tighter. That fixed my leak…
87 911 Carrera Coupe
Old 02-14-2023, 05:51 PM
Found this thread this morning over coffee:
Oil Pressure Switch Fitting Torque
26 seems fine for the adapter and maybe between 11 and 13 for the switch itself. Can always tighten more later on...
Appreciate the feedback airkewldfan.
Erik
1986 911 Coupe
1986 911 Targa
Old 02-15-2023, 10:29 AM
PCA Member since 1988
On things like that, I go just tight enough that it doesn't leak.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-15-2023, 01:04 PM
Tighten the oil pressure sender into the block off the engine in a vice, then snug that block to the case with the banjo bolt. If you tighten it held by the banjo bolt you risk snapping the case....
Ah your doing the switch, input my adapter on and torqued it, the switch is loose fit untill I hookup oil feed line for the turbo .
Old 02-15-2023, 03:34 PM
Walt Fricke's Avatar
I'm with Pete. Torque is important in some applications, like rod or head or case or cylinder bolt, or flywheel bolts. These bolts need to be stretched far enough that the residual tension exceeds the forces trying to move the bolted surfaces apart.
Otherwise, absent some special vibration or other condition, getting things snug is good enough. The larger the bolt diameter, the more force to get things snug. The tools you use can help you - longer handles versus shorter handles. A hollow bolt (like a pressure sensor) you wouldn't want to use a 16" Crescent on. You just need to crush the washer a bit so you don't get a leak, and you can add a half turn more if you see a little leak developing.
Old 02-15-2023, 04:43 PM
Thanks guys...
Appreciate it.
Erik
1986 911 Coupe
1986 911 Targa
Old 02-15-2023, 09:52 PM
