LinkBack | Thread Tools | Rate Thread |
3.2 Carrera w/ headers 2-in muffler fitment help? SCART, Dansk, Monty.
My 1987 has M&K longtube headers, backdated oil lines, backdated muffler mount and an M&K 2 in / 1 out muffler.
Brian at M&K told me that the header outlets are in the same spot as the SSIs / early heat exchangers. The M&K MKM27 muffler is too loud for the car's use case, so I intend to try SCART Riva, Dansk Sport and Monty 2 in / 1 out mufflers to see which sound quality and volume I prefer between the three. Per the attached pics, I know that the original 1 in / 1 out 3.2 sausage shape muffler has a relief (approximately 12mm deep) to make room for the 3.2's larger engine console (carrier). As a result, a 3.2 muffler can be used on a 3.0, but not the other way around. Given my recent SCART Riva mounting issues... SCART Riva specific muffler bracket MIA. Did I figure out the problem? ...it looks like this may also be the case with 2 in / 1 out sausage shaped mufflers. Can anyone confirm this? The pictures in the Dansk catalog show a similar relief, but I don't know if those are generic photos, or if the actual muffler is shown. Who can confirm which 2 in / 1 out SCART, Dansk Sport or Monty muffler will fit a late 3.2 Carrera with M&K (or SSi) headers? Bonus points for part numbers. My neighbors and I thank you. ![]() ![]() ![]()
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Titanium User
Frank, I have this one in my garage I plan on installing with SSIs on my 87 Euro Coupe.
2 in 1 out Dansk Stainless Sport Muffler with stock sized tip so I can add a black OEM tip. Has a relief for the 3.2 carrier. Dansk PN 92.512SSI 39/20 Few months from installing it all but I'll let you know how it sounds when I do. ![]() ![]()
Buy some Titanium Lug Nuts! http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html ig: @ti_porsche_products Last edited by dg567; 02-21-2023 at 01:16 PM.. |
The new matte (or, as they call it "mat") finish! Sexy. Me likey.
Thanks DG! SCART appears to have an option for the stock tip too. Monty does not appear to offer that option. Could preclude the Monty from consideration. Also, from what I gather, "Mike from Dansk" used to frequent Pelican (post 5 here)... Dansk muffler for 911 SC with SSI heat exchangers ...that's no longer the case. Does anyone have a contact there that can provide technical info? This was illuminating... " Here's what I learned from discussions with Mike from Dansk when I went through this on my SC. 60mm will be closest to stock. It'll be louder than your stock SC because it's a two in with more direct exhaust flow to the muffler. The higher dB is not due to the muffler though. 70mm has "sport" baffling and is a free flow design. This is what I had on my SC and originaly on the track my SC was hardly audible with a helmet on at speed. With the 70mm muffler "sport" it was much more noticeable. However, I had a 2-out and I am sure that makes it a bit louder than a 1-out. 80mm is the same at the 70mm but has larger out pipes. I've been told that this version doesn't make any more power but is louder which is the driving force behind a lot of muffler upgrades."
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" Last edited by famoroso; 02-21-2023 at 01:37 PM.. |
Titanium User
I wanted to keep things looking factory which is why I went with the 60mm outlet and factory tip.
I had an 84mm single out Dansk on another Carrera years ago and it was too loud for my taste.
Buy some Titanium Lug Nuts! http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html ig: @ti_porsche_products |
The car sounds great Frank, just back it into the garage and don't worry about it...
____________________________ If it's not leaking, it's out of oel... |
MK Headers and Scart from Arling at Rstrada.
https://youtu.be/k32GiQqxd_A ![]() Very very happy with it. Car is a 76 2.7 |
It does not make sense that Scart doesn't have a readymade bracket for your 3.2. That's what they do, make "newer" cars sound "older"... and clearly they have a bracket for their other sausage. Very strange. |
I have a Dansk 92.512SSI en route. SUPER excited to mount it and hear the goodness. Thanks DG!!
Fingers crossed I get it in time for the Hill Country Rally.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" Last edited by famoroso; 02-22-2023 at 10:05 AM.. |
It’s interesting about Dansk. The 356 Registry folks severely hate them. Quality and weld issues. There seems to be love for them from the 911 crowd though.
I had the below 84mm SS Dansk Sport 1 in / 1 out on two of my 3.2s for a while. It made the right noises and also dynod well. The welds were nice enough. It was an older unit.
Don't get me wrong, I value artistic quality welds and all, but as long as the welds are functional, they don't have to be THAT pretty for me. ![]() ![]() ![]() ![]() ![]()
Frank,
This is the muffler you want to use. Same deep throaty sound as a stock Carrera but a bit louder. Quote:
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Frank, get the dansk sport 2in2out it will sound much like the dansk 1in1out you already had.
While my inner 17 year old likes the idea of more tips, this car will remain a single tip-er. My '89 is slated to get a GT3 box.
Frank, I meant to say get the 2in1out Dansk pipe.
Phew!
Per DG's post, Dansk 92.512SSI is ordered and I just received tracking info. It's en route to me from Anaheim and is slated to arrive this afternoon. W00T! I know what I'm installing this evening.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" Last edited by famoroso; 02-23-2023 at 07:31 AM.. |
Titanium User
I’m super jealous - post some videos. I won’t be installing mine for a few more months.
Ordered at 6:40a yesterday.
Delivered at 11:19a this morning. Not too shabby! It weighs 1.25 lbs more than the original 1 in / 1 out muffler and 8.8 pounds more than the MKM27 muffler, but when it comes to lower / deeper tone, I think you need a muffler with more volume / mass. We're about to see as I'm prepping the install right now. Please note the imported polishing cloth. Made in Denmark! :-) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I'll report back post install (assuming it mounts up without issue).
Frank, I think this muffler should work well for you and with a decent sound.
While you are installing could you possibly estimate the length of the runners from the head to the collector? Use a string to get an estimate, then measure the string. I'd like to know how long the runners are. Thanks.
This old man went with Sri and Dan’s on a 83 cab. Why because I got frugal. If I was ding it again I would be all in on monty
