charles
MFI crossbar return spring
Hi
My crossbar return spring appears to have slipped (arrow), I think it should be on top (star).
Someone previously also repositioned the pivot point of the spring - not sure why (pict2)
I'd like to either replace, or reposition the current spring, as my idle is not returning to set point always.
In either case I'm not sure how to approach that - lots of spring tension!
Suggestions for repositioning or replacing with new?
Old 02-26-2023, 10:57 AM
edit: is the other end inserted into the the hole
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 02-26-2023, 04:51 PM
charles
No, the pivot end can be seen in 2nd picture by the large washer
Old 02-26-2023, 05:29 PM
charles
In general, how do you wind spring up say 1 more turn?
Old 02-26-2023, 05:30 PM
