PCA Member since 1988
Then be sure to park on a hill!
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-22-2023, 01:49 PM
Over on another thread about not starting, someone referenced the WOSP hi-torque and lightweight starter sold at Pelican. It's only $209, and built on the Nippondenso starter core. Consider it as good and inexpensive insurance.
Old 03-22-2023, 01:51 PM
Still here
pmax's Avatar
Originally Posted by MrBonus View Post
No, I don’t believe it’s a starter issue. The car starts just fine 99% of the time. Occasionally, and I mean very rarely, I get literally nothing when turning it all the way to start.
A bad ground like the tranny strap would make sense too.
Check the tranny strap grounds first.
Put your bro's lift to good use if you don't want to jack it up yourself.
Old 03-22-2023, 08:32 PM
Enginerd
TxGerman's Avatar
My problem was similar, but maybe not exactly the same. Definitely check your ground strap, but if it appears to be ok (mine was) then as has been mentioned it is either the start switch (964-613-012-00) or the starter. For me, it was the start switch. It would fail occasionally and then one day just said "nope, not gonna do it anymore". I did also end up replacing my start motor, but that's because it too decided to stop working a few months later. I decided to go with the lightweight High Torque starter.
1982 Guards Red 911SC, 1994 Riviera Blue RoW 993, 2020 British Racing Green Macan GTS
Gone but not forgotten: 2017 GT Silver Turbo S, 2012 Guards Red 991.1 C2S, 2017 Carrera White Macan GTS
IG: @pcar911fan
Old 03-23-2023, 04:34 AM
Replacing the transmission strap on my '88 cured it for me a few years ago...
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 03-23-2023, 06:15 AM
83 Targa
I have the same problem with My ‘83 and just minutes from DE. I’m thinking my issue is in the ignition switch. PM if you can figure it out or get into the ignition. I have a lift in my garage too. Bill
Old 03-23-2023, 01:58 PM
Kind of Blue
MrBonus's Avatar
Will do! You're a stone's throw from my home. Do you ever head up to Northbrook Marketplace for cars and coffee?
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 03-24-2023, 02:32 AM
83 Targa
Yes I do head up to Northbrook. Red ‘83 Targa. Look for me.
Old 04-10-2023, 09:36 PM
