Megasquirt question - What kind of connector does my injector use?
Per my other recent thread, I had a small engine fire that burnt up one of my injectors. I’ve already got another injector on its way. I haven’t had the opportunity to inspect it closely yet and try to remove it, but I’m assuming there’s a good chance that the harness plug will need to be replaced, at the least. Injector is a 30lb/hr Accel injector:
https://www.autozone.com/fuel-systems/performance-fuel-injector/p/accel-performance-fuel-injector-150130/429950_0_0
How do I identify the plug this uses (that is, what is this plug type called), and where can I buy a replacement? Once I know where I can find the plug I can see whether I need a tool to connect it to a new pigtail.
'80 SC Targa
Avondale, Chicago, IL
Old 03-15-2023, 05:42 PM
al lkosmal's Avatar
I believe that they are described as Bosch EV-1 style connectors.....
I don't think that Pelican sells these connectors....so here is a link to a source ....
https://www.diyautotune.com/shop/wiring-components/fuel-injector-connectors/
and if you search on your Autozone website for "fuel injector connector"
you'll find this......
https://www.autozone.com/fuel-delivery/fuel-injector-wiring-connector?filterByKeyWord=autozone+injector+connec tor&fromString=search&isIgnoreVehicle=false
RGruppe #669
http://www.x-faktory.com/
Old 03-15-2023, 06:17 PM
Perfect! Thanks. Seems obvious, but I didn’t think of that.
'80 SC Targa
Old 03-15-2023, 06:25 PM
