Using Wheel Spacers
My 77s Targa has metal SC flares so there is room for more tire...I can source 2 16 x 7 or 16 x 8 fuchs but then need new tires too..so a bit expensive
My current setup uses a 1 in bolted on spacer for the rears ![]() But I worry about what additional stress it places on the suspension etc Should I be concerned..its not tracked, more of my run about in the summer I can always just go back to no spacer if there is a concern and address the 16 x 8s when ready thanks for your input Bob
1977 911-S Modified (3.0 SC Motor/Flares) |
Watching an episode of The 900 Series, the shop owner gave a explanation of the use of spacers as a way of correcting the asymmetric offset of the rear of the SC. An example of this was the passenger side is closer to the fender lip than the driver side. Take a look and measure and you’ll find the difference. Using spacers as a way to enhance the appearance of too much emptiness in the wheel well that makes the car look “odd”.
He recommended nothing more than a 1/2” spacer to correct this, I think he mentioned how thicker spacers do have a some negative effect. As for spacers in general, he said the lowering of the ride height will determine tire width and clearance as would an alignment to compensate. As you say, your 1” spacers are not a problem with rubbing, but how’s your alignment as this might cause tire wear and longevity. The contact patch or any wear pattern could tell you a lot. Spacers been around and used for decades, my concern too would be stress on bearings and bushings when wheels are extending too far out, especially if beyond the my needs. A smaller spacer on driver side for the asymetric offset but with a wider tire profile and a correct alignment. |
RETIRED
I have run 1 inch spacers on 6 and 7s for years. No problems.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
EC: I had the car aligned by a race shop with the spacers and no problem, I will do the measurement anyways out of curiosity now :-)
JB: Good to hear, the car handles well with the spacers, but as EC stated, stress on bearings/bushing was a concern that you ve dispelled Thank you both
Crotchety Old Bastard
Those are adapters not spacers. Spacers use longer studs, adapters use an extra set of studs.
930's run spacers on the rear from the factory, no issues. When using adapters it is extremely important to check the torque on the nuts attaching the adapters after a few miles, then re-check the wheel nuts a few miles later after they are back on. If the adapter nuts get loose you can damage your lugs and the adapter or lose a wheel, same as for the wheel nuts.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Tx Walt
Yes, i torqued to 94lbs in midst of gravity bleed now, thought i d try that method :-)
Cheaper than a new set of wheels, but its added weight... and rotating weight is a x3 penalty. I wouldn't worry about it on a street-car too much.
jt '83 SC '96 M3 6 Bicycles 2 Sailboats |
Use factory hub centric wheel spacers and longer studs you will have no problem. Mine are double stacked in the rear its been like that since the 80s for 100k. Wider wheels are not much easier on it than spacers. You are putting tire farther out from the pivot point either way.
82 SC , 72 914 |
Insert Tag Line HERE.....
I ran 3” adapters and 1” on the front for thousands of hard track use with no issues..
Marc |
RETIRED
Early Turbos had spacers from the factory
Original Owner
I like to keep them under four inches....
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
PCA Member since 1988
The turbos also has different swing arms which locate the axle bearings differently. If you are using or thinking about, spacers, try to make the centerline of the wheel+spacer end up in the same plane as the centerline of the original wheels, which should be between the inner and outer bearings. This will keep the loads on the bearings near the original design.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 03-24-2023 at 07:32 PM.. |
