No diode is needed for the FP relay on a CIS, as there is no electronic driver circuit to protect upstream.
Subject is about modifying a F9 SSR to drive a FP on a CIS car, which I think is not possible.
Gilles
RoW 88 Carrera coupé
Old 08-07-2024, 01:19 AM
AndrewCologne's Avatar
Yes it is needed on newer sc with RPM limiting switch and btw. it is exactly the difference between a black and a red relay.
Watch the wiring diagram as on the red FP relay terminal 85 and 86 the RPM limiter switch is directly connected. And as this RPM limiting unit holds sensible electronics you should at least make shure that a flyback diode is present in a relay like used in the red one. Once the Relay switches off the inductive load of the relays coil will give a voltage spike towards the RPM limiter.
And here I'm with you.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control
All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models:
https://nineelevenheaven.wordpress.com/english/
Old 08-07-2024, 09:00 AM
