Senior Member
Removing AC bracket without dropping muffler
Is it possible to remove the AC bracket without taking the muffler off on an 88 911? My mech mentioned that I do not need to take it off, and I should have yanked this when the engine was out - what was I thinking?
Looking at other threads, it looks like with some skinny wrenches I should be able to remove the last two bolts going from below, and the 8mm hex under the top plate. Doable? Or should I be drug tested on this?
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 03-29-2023, 08:29 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Bracket
I think you have answered your question.
No need to remove anything in advance.
Semper Fi
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-29-2023, 11:03 AM
I recently re-installed my bracket and had to drop the muffler to do it. I think you will struggle without dropping it
Old 03-29-2023, 01:30 PM
dtwa's Avatar
I took my bracket off w/o removing the muffler. I did have to undo the mounting straps on the muffler and remove the crossover pipe for the heat exchangers. I could then access the two (I think) bolts holding the aluminum AC bracket to the steel bracket surrounding the crank pulley. —Dave
1985 Carrera 3.2 • Prussian Blue Metallic
Old 03-29-2023, 07:38 PM
