The voltage fluctuates, that's a screen shot from the video I took.
Here is another screen shot at 12.16v. Should the voltage fluctuate like that?
Old 04-13-2023, 09:22 AM
To do any adjustments do you leave the oscilloscope connected and adjust the 3mm Allen screw
in the sensor plate? What range would it need it to be so I am within range or would I need to get a CO2 reader to test what's coming out of the exhaust.
Old 04-13-2023, 01:47 PM
AndrewCologne's Avatar
For setting CO via duty cycle all has been explained here where you took part :-):
Using Oscilliscope to Set Duty Cycle
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control
All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models:
https://nineelevenheaven.wordpress.com/english/
Old 04-13-2023, 09:07 PM
