Schulisco's Avatar
Originally Posted by andrewcologne View Post
the "tricky" thing is, that many 123 users do simply use the known "ported" vacuum connection which leads to the dizzy. And here this gives a total wrong signal as ported vacuum is only available at a slightly open throttle. With this kind of vacuum you will never get the whole "common" map vacuum range needed for a proper timing at "all loads".
So ... To get a full map signal ...
For 911 sc till '79 without ecu this is the same vacuum line like connected to the wur.
For 911 sc from '80 with ecu its the same vacuum line connected to the cruise control and deaccel. Valve.
+1
Fo completion here's a link to the SWCchips website, they have pictured the curves from the 3.2 Carrera up to 993
https://www.swchips.com/ignition.htm
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 04-13-2023, 06:17 AM
