Headlight switch installed wrong?
Is it possible to install the headlight switch incorrectly? My running lights only come on when the knob is pulled out all the way (2nd click), and they're on even if the car is off. By contrast, the headlights only work if the knob is pulled out halfway (1st click). I'm wondering if I reinstalled the switch wrong the last time I was in there...
http://forums.pelicanparts.com/porsche-911-technical-forum/1114917-jedi-911sc.html |
double check your wires
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
I feel like an idiot - I was confusing the hazard light switch with the headlight switch in my mind. I thought the headlight switch was two pieces for some reason. Doh!
Thanks for that diagram. I'll check 'em all out later today.
is this the same for a '81 911
Do you have the same diagram for a 1981 911? With wire colors included? it would be so helpfull!! Also, do you have photos of the headlight cables, pictured, and where the wires go?
Pictured is 1 cable with Yellow, Blk / white (I see some green on it...not sure if its green paint). The other connectors and single Grey ![]()
