Usually fuel pumps make a little noise so when in "Ignition" setting on the key, the pump should be working.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
We'll pushing her out of the garage backwards didn't work. Not enough distance and the gearing is to short. Just came to a complete stop.
So I ended up doing what I expected. I have a big winch I used to use on my car trailer, now sold. Bolted it onto the 4 post lift. Then I hooked up my AC/DC converter, recently purchase just for this, and pulled the car into the garage onto the lift. Got the starter out, put it in my vice and sure enough, solenoid ok but the starter has a issue. Waiting for the new starter to arrive on Monday.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
