Cevan's Avatar
Cam timing - how am I doing?
I’m at the point in my rebuild where I am timing the cams on my ‘86 3.2. First time doing this so just wanted a little feedback to confirm I’m doing this correctly. Per Webcam, I’m shooting for 1.9 - 2.2mm with .1mm lash with 20/21 cams. I am trying for 2.05mm, splitting the difference. I installed the #1 intake rocker, set the lash to .1mm while crank is at TDC. Installed my dial gauge, zeroed it out and spun the crank 360 degrees. I measured 1.25mm of lift.
I then continued to rotate the crank until at got to 2.05mm, removed the sprocket bolt and pulled the pin, at which time the cam rotated. Of course! I had read this may happen. I tried this a second time and same result.
So I started over, back to TDC, “930” mark pointing up, inserted the pin and rotated 360 degrees again. This time I was short again at 1.3mm. So I figured I would try and advance the cam when I was back at TDC so I rotated back around to TDC, gauge went back to zero, removed the bolt and pin. Then I used a small punch to gently rotate the cam relative to the sprocket maybe 1/2 a degree so I could move the pin one hole. Reinstalled the bolt and rotated again. This time I was closer to 2.05mm but not quite there. I repeated this maybe 3-4 more times and crept up on 2.05mm. Just prior to the last time, I tightened the cam bolt up to about 30 ft lbs as I felt this time would get me there. I then torqued to the 120 ft lbs and rechecked. Still at 2.05mm. I repeated this on the right side with #4 intake. I got to 2.07mm. Is this close enough?
I’m going to recheck the left side again to confirm my measurement, and then probably the right side again. Thanks for the feedback.
1986 Carrera coupe - black on black
1972 CB500/4
Old 05-17-2023, 07:08 AM
Following
Old 05-17-2023, 07:11 AM
walt's Avatar
.02 mm variation is good that's less than .001 in. You can use your cam holder to rotate the cam back to the correct setting if it moves which it will with only one rocker in place. I found this video from Klassic that explains the procedure really well.
https://www.youtube.com/watch?v=u2HbSNdAB3A
Walt
82SC 3.0
81SC 3.6
Old 05-17-2023, 07:52 AM
Put all the rockers in next time and take up any slack. Then the cams won't move. Never understood the only one rocker approach.
206 637 4071
Old 05-17-2023, 08:43 AM
Cevan's Avatar
My engine is 3.2 and there is no way that I'm aware of to rotate the cams CCW independent of the sprocket.
1972 CB500/4
Old 05-17-2023, 08:58 AM
Thanks for the great tip John.
Old 05-17-2023, 08:59 AM
With bolt style cams, set the cam timing where you want it, then pull the pin and turn the crank to the Z1 position and put the pin in whatever hole will take it. Snug the bolt and recheck. The cam will stay put as the crank is turned ( if you have all the rockers in place).
206 637 4071
Old 05-17-2023, 09:18 AM
Cevan's Avatar
Thanks for the tip. Too late for me but hope it helps others. To be honest, I was a little hesitant to start spinning the crank with any more than one rocker in initially.
1972 CB500/4
Old 05-17-2023, 10:08 AM
Maybe it's idiot prevention so when you spin the crank 360 without moving the cam you're only chewing up one cylinder's worth of stuff than three.
1982 911SC
Old 05-17-2023, 11:24 AM
proporsche's Avatar
yup... this^^^^
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 05-17-2023, 01:26 PM
shoooo32's Avatar
Wayne's book recommended the one rocker approach. As a noob I had no reason to doubt it.
-Tony
Instagram: @Pablo_the_Porsche | @RuchlosRallye
AchtungKraft #002
Old 05-17-2023, 01:38 PM
Wayne’s book probably suggests one rocker approach for the first run, when your measuring valve to piston clearance. It’s easier with all rockers are installed.
Question though, what’s the issue with having both sides timed differently, the engine wouldn’t run as smoothly right?
Old 05-17-2023, 02:02 PM
All roads lead to Rome
Old 05-17-2023, 02:25 PM
Bland
unclebilly's Avatar
Why 2.05 vs 2.22? I think I set my race car up for max opening and got it bang on with DC40 cams.
Old 05-18-2023, 06:49 AM
Cevan's Avatar
Per the information from Webcam, the instructions state to set the cam to 1.9 - 2.2mm. Splitting the difference gives 2.05mm.
Can you explain why you suggest 2.22mm? I do not race my car btw. Purely street driving.
1972 CB500/4
Old 05-18-2023, 07:22 AM
