Engine lid no popping up
1984 Carrera 3.2
When I pull the engine lid handle, the lid no longer pops open like it used to. I have just enough arm length to do it, but it’s a pita. The spring in the make portion on the lid appears in tact, not visibly broken. Any ideas? |
PCA Member since 1988
If the spring is intact, it should pop up at least an inch or two. Since you can reach and open it with one arm, it appears to be releasing. Your car is a Carrera, so it should have the AC evaporator inside the lid. I would be looking for something weighing down the lid or pulling down on it.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Maybe try a little lubrication around the spring and plunger to try to free it up a little
Titanium User
I just lubbed the latch, spring and changed the rear shocks and my early lid opens up on its own when I pull the handle.
Buy some Titanium Lug Nuts! http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html ig: @ti_porsche_products |
Be very careful if you attempt to do any adjustment as you may not be able to open the lid afterwards. I advise removing the grille before adjustment, then if it sticks you can reach in and release it by hand.
Roy
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
likely the hinge pivots are seizing if the spring is in tact and its a factory lid.
i would NOT be adjusting that latch as mentioned or make sure you have access first
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Those little adjustable rubber tits are are what pop the lid up. Screw them out or replace them.
Are you parked on a flat surface? Trying shifting the lid left and right as another person pulls the handle.
Ass-engine Nazi slot car -- PJ O'Rourke |
Would it be more helpful to look at a new spring and or hood strut deepening in which is worn or not working? If after releasing the latch the hood opens all the way the strut is fine. If the the hood stays down in the latched and locked position after pulling the release it either needs lubrication, adjustment, a new spring or a combination of all 3? https://www.pelicanparts.com/More_Info/NLA51105302.htm?pn=NLA-511-053-02&gclid=EAIaIQobChMI8J73pMS2_wIV5S3UAR2KRwzTEAQYASAB EgImxvD_BwE If I am wrong please let me know, I'm not nearly as knowledgeable about these car as you all and would love to know for future reference. I suppose this response is to just clarify for my own curiosity. |
They do adjust the lid side to side, but also if they are extended out a bit, will pop the lid up and lift the striker out of the latch, regardless if the lid shock works or not. They act as a spring.
Original Owner
What the distinguished Mr. Walker possibly means is if those bumpers are bad or not properly adjusted then the rear deck possibly sits too low. This could then result in the weighted deck not popping open when the 40 year old tired spring pushes....
Maybe it needs another 2 mm....
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
Do what
JSV798 said. I had to cut my grill out. I have the pieces but would have to source the aluminum connecting rods. I opted to order a replacement from our host. There is a thread here about opening if stuck but it didn't work for me. It will save you about 500 to pull the grill. I had it adjusted when it was in a local shop. This was after I bought new latch hardware, again from our hosts. I guess I should make a profile. 67 body. |
Yep .. this ^^^^^
Maverick Region PCA, Fort Worth/Dallas area 1987 911 Coupe, Black M491 3.4 // Turbo-Look Registry # 1249 1977 911 Coupe, Metallic Sienna (I think!)/Lobster SOLD 1982 924 White, SOLD long ago 1966 912 Red, SOLD, totaled a week later by its new owner |
The little rubber bump stops indeed get old and hard. Instead of acting like rubber, they are like hard plastic. They are easy to replace, they just spin out, and the new ones spin in.
I would suggest you replace those first if they are old.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Just one more thing to add to my endless to do list. I can see how it would help after that spring to get the striker out of the latch. The spring at that point would be doing nothing.. thanks I suppose there are worse ways to spend 8$.
