Discseven's Avatar
Test fit looking at oddball corner. Prior slider plate I had had no mount from the slider to the compressor here. Reason is obvious. I could have skipped it too in this plate remake but think there’s just enough space to make a 4th bolt work. Jam nut here is certainly not optimal but better with a bolt & jam compared to no bolt at all. Will get rid of the powdercoat where the jam nut seats. Blue lock it. If necessary, can hog off a bit of flange or bracket material. Thin wavy? Bolt shaft = 40mm. Spacer = 3/8". Bracket = 1/2" thick.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-06-2023, 10:15 AM
I have been using QCad Pro ($38) because it's Apple Mac native and pretty easy to use for 2D only. A couple youtube videos about how to use and you will be off and running.
Old 07-06-2023, 05:02 PM
Ace of Spades
Originally Posted by SBell View Post
I would recommend Fusion360 for beginner friendly CAD programs. The hobby license is free at it has a lot of available functionality once you are ready to go deeper. I found out a long time ago I really quickly ran into the limits of TinkerCAD when trying to edit parts I already made without breaking other parts of the model. Then again that was probably 8 years ago so they've probably made some changes since then.
Sent from my SM-G991U using Tapatalk
What he said
You do however need some pretty good graphic processing power.
1977 911S - high mileage and a bit rough but mostly original. Soon to become a bit of a hot rod.
Old 07-06-2023, 05:30 PM
Full Send Society
I use both sketchup on my Mac and shapr3d on my iPad Pro. Both have their pros and cons- shapr3d is super intuitive and easy to use but neither are as powerful as fusion360 but conversely shapr3d took almost no time to learn.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 07-06-2023, 06:36 PM
