Newbie question: how do we check all cylinders are firing.
Have a 1987 911 targa. Everything is great but I was reading one of the builds where the owner figured out that one of his cylinders was not firing.
Question is. How do we figure that out? Do we like hear for knocking? Do we do the stethoscope methods? What do we do?
Apologies if it’s already discussed.
Silver 1987 Porsche Targa Carrera
Build thread: 87 Porsche targa! projects tracker
Old 06-17-2023, 09:01 AM
al lkosmal's Avatar
Use your timing light by connecting to each spark plug wire, one at a time
RGruppe #669
http://www.x-faktory.com/
Old 06-17-2023, 09:11 AM
targa72e's Avatar
I have used a laser thermometer to check each exhaust pipe. If one is not firing (or firing at the wrong time because plug wires were mixed) you will see a lower temperature.
john
Old 06-17-2023, 10:54 AM
PCA Member since 1988
Why do you think they are not all firing?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-17-2023, 12:57 PM
Mike80911's Avatar
You could also use a test light to ground each wire. Connect a test light to ground then stick the probe through the top of the wire where it goes into the cap. If the cylinder is firing the idle will drop.
89 930 Cab Black
11 Cayenne
Old 06-17-2023, 01:28 PM
Still here
pmax's Avatar
A thermal scanner would be the perfect tool for this, hands off, no mucking with spark plugs etc.
Old 06-17-2023, 02:11 PM
Dr J's Avatar
Get a squirt bottle that can send a stream rather than a mist and aim at each exhaust header, one at a time, noting how quickly the water evaporates. The one that does not evaporate quickly is the dead cylinder.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 06-17-2023, 02:34 PM
+1 on DrJ. I use the windex spray bottle.
Bruce
Old 06-17-2023, 03:21 PM
I am sure mine is great. The engine and smooth and pulls strong. But i was wondering how do we check this. So asked.
Old 06-17-2023, 07:55 PM
Cool answers. Thank you. I learnt something new today.
Old 06-17-2023, 07:56 PM
Easily Confused
dtxscott's Avatar
Simply unplug each spark plug one at a time with the engine running. If the idle stumbles or changes, that cylinder is functioning
If the idle is unchanged when pulling the plug wire, that cylinder is no bueno.
Scott C.
'08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65
Old 06-18-2023, 01:32 PM
Targa_PB_78_SC
mike sampsel's Avatar
Originally Posted by al lkosmal View Post
use your timing light by connecting to each spark plug wire, one at a time
+ 1
BareRearedRookie
Old 06-18-2023, 03:28 PM
New-ish 911SC Targa Owner
pampadori's Avatar
How i do it:
I plug in my laptop to my ECM and open InfinityTuner software. While running, i deactivate each individual coil-on-plug one at a time to listen for the change in idle. Sometimes I deactivate each injector instead. :P
But same could be achieved by unconnecting each sparkplug wire one at a time.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 06-19-2023, 06:18 AM
Am gonna learn what is a timing light now.
Old 06-19-2023, 10:31 AM
Senior Member
Superman's Avatar
I strongly recommend against this. Experiencing 30,000 volts is an interesting experience. It teaches you to never touch the ignition system of a running engine.
The timing light method is a good one. As is the infrared thermometer method. Every tool box should have both these tools.
Mocha 1978 911SC. "Coco"
Old 06-19-2023, 04:16 PM
Still here
pmax's Avatar
Along that vein, I was just about to mention the instant phase transition of water.
Old 06-19-2023, 05:42 PM
Senior Member
Superman's Avatar
Yup. If you want to burn yourself really good with hot water, turn it to steam.
Fun Fact: Harkening to the days of steam shovels and other steam-powered equipment, the logo for the International Union of Operating Engineers is a steam pressure gauge with the needle pointing to 420.
Old 06-20-2023, 05:57 AM
spoke's Avatar
A follow up to the OP's question of how to find a cylinder which is missing. I had a similar experience where the engine would run fine then just start missing a bit. It would run good for a second then miss, good, miss. Or miss a lot.
Looks like the issue I had was the plug wire plug socket was cracked and maybe or maybe not making contact with the plug. Not sure how testing would find this.
BTW, these are Beru wires installed about 8 years ago. Almost every one was cracked and 2 just fell apart when slightly stressed. Which plug wires would you suggest to replace?
Find Spoke's LED Products:
www.spokeworksled.com
Old 06-25-2023, 03:05 PM
al lkosmal's Avatar
I have been using Clewett Engineering spark plug cables....they are very good/high quality
RGruppe #669
Old 06-25-2023, 05:32 PM
wrxnofx's Avatar
Meh, I've done it plenty and not ever had an issue.
Curious about the timing light method. How does that method insure the cylinder is firing? All a timing light tells you is that there is an ignition pulse being sent down the wire. It's not actually telling you if the plug is firing. Similarly, it's not telling you if the injector is dead. Both of these are possibilities that a timing light won't show.
An IR thermometer/camera is probably best.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 06-26-2023, 03:08 PM
