JCFL
Location: Caraquet, New Brunswick, in eastern Canada (600 miles east of Boston)
Spark Plug 6 - remove AC compressor or not
Hello guys,
Should I remove AC compressor to reach plug no. 6 ? I know its a pain. I have not done it in quite a while and I believe that I would have removed the compressor in my prior 911s. Anyone cares to comment ? Thank you.
Jacques 1986 911 Carrera Coupe - since April 2022 1982 911 SC - 2010 - 2017 1984 911 Carrera Coupe - 2006 - 2009 |
JCFL
Checked again - it seems I will have no choice...
Yes it’s best to detach the compressor and swing it out of the way to do anything on the upper right such as valve cover, adjusting valves, and changing plugs
Easy to remove the mounting bolts, and swing it over to lay on the fender. Of course lay a thick towel or something similar under the compressor. No need to disconnect the hoses.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
JCFL
Thank you guys. I am there and I appreciate your confirming the process. Cheers.
Lay it over on the engine. Carreras have room for that, unlike SCs etc.
If I remember correctly a engine bay protector pad has an extra-thick layer of vinyl, a patch ..on it for this very maneuver...for SC owners who still have an A.C. unit
jt '83 SC '96 M3 6 Bicycles 2 Sailboats |
Still here
Lay it on the engine, not the fender. With Carreras anyway. But I mentioned that previously and you must have missed it.
John W
I don’t mess with the compressor on my 3.2. I use the spark plug tool that comes in the tool kit. Works great!
Still here
Noted.
Which method did our OP choose ? |
JCFL
Sorry, what is an OP ?
Still here
JCFL
Ok thank you.
I chose the over the side method, with a thick towel under the compressor to protect the paint. Thanks.
Still here
Yeah, looks like the act was already done prior to John's better recommendation. Might be worth practicing though given it's already out.
