82 sc cigarette lighter
Ok need some help, I removed the cigarette lighter then figured out that the only way to get it out we to remove the air box. In the process I disconnected the center lead to the thing without being able to see it. I also lost the center pin. http://forums.pelicanparts.com/ultimate/mad.gif
I have look at all the posts and wiring diagrams and it states that I should have a black lead for the power. I have two wires with no home a white/green wire that I believe is for the rear fog lamp left disconnected and taped. The other is a red/white wire that seams to be in the same wiring harness as the brown leads for the lighter. http://forums.pelicanparts.com/ultimate/confused.gif
1982 911sc
1999 996 Cab
Old 07-06-2023, 12:31 PM
Mike80911's Avatar
If you remove the center vent you should be able to see the back of the lighter and the wires. There should be 2 wires usually one has a spade connector and is brown that connects to the housing of the lighter and the other has the pin that slides into the back of the lighter.
89 930 Cab Black
11 Cayenne
Old 07-06-2023, 06:24 PM
ROW '78 911 Targa
timmy2's Avatar
They used red/white for later year SC’s instead of black.
Be careful, it is an always hot wire with ignition on.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-07-2023, 12:40 AM
