What did i do wrong?!
Please don’t roast me! I took the car apart for paint, now when I put the suspension back together, the drivers side is set back about 1.5 inches.. I don’t understand what i could’ve done wrong?!
Show it with the wheel off, and closer.
I have new brakes and front sway bar coming, so it’ll be apart again but not sure how it could be off so much.
Lots of caster, maybe, but the top of the shock mount would have to be pushed waaaaaaay forward for that much.
72 911 Although it is done at the moment, it will never be finished. |
Senior Member
Think you need to show the strut mount in the trunk to see the position. Agree, could be a "simple" caster issue. It looks pretty far forward in relation to the strut housing in the wheel well.
Chris 1988 911 Carrera Targa (driving project started JAN 2022) 1970 911E - Long since gone 1972 911 Targa - gone 1987 911 Carrera - gone Retired FA-18C Driver |
Did you remove the strut mount for paint?
Did you replace the front pan? I just dealt with this on a car last week but the wheel was too far forward. The last person to assemble the front suspension didn’t have the control arms/bushings pushed all the way into their housings
it's not leaking....it's just marking it's territory |
I feel like someone else did this exact same thing just recently. The thread should be out there....
Edit: I don't think it's caster, you'd need something like ten inches of caster to get that much movement at the hub! Edit again: I can't find the thread but I'm pretty sure the other guy had an issue with the control arm bushings or mounting points of the control arm.
1982 911SC Last edited by David Inc.; 08-03-2023 at 07:26 AM.. |
Loosen the strut mounts and put car on the ground. Check strut make sure it’s straight they do get bent believe it or not. What’s the car history?
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
7.0:1 > 11.3:1 > 7.0:1
Flare is too far forward.
[QUOTE=Jim2;12059290]Flare is too far forward.[/QUOTE
Cant be, it was fine before i took it apart. Ill disassemble and start over. |
Can you snap a photo of the control arm from underneath, showing the mounting points and full shape of the arm?
1982 911SC |
Titanium User
Any photos of it before it was taken apart? Unless its the angle of the photo, there doesn't seem to be enough space between the flare and the turn signal.
Buy some Titanium Lug Nuts! http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html ig: @ti_porsche_products |
Could be the angle of the pic. @jugar23 if only the driver side is skewed you should be able to measure the distance from the reflector to the wheel opening on both sides and see if they are significantly different from one side to the other.
take a picture if you can from the bottom cross section so we can see it better to help you.i doubt is the body-fender
problem.. Ivan oh ya once you figure this out i would change the rotors;-)
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Maybe a little crazy, but could they have sent you back the wrong fender after paint? There is a lot that looks weird about that fender in the photo.
Mark
1979 911SC Targa |
Ivan
Titanium User
Is the fender fully mounted? Looks like its sagging towards the front end of the car.
Grappler
Maybe post a before pic so we can see how the fenders lined up.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
Please don’t say, that now I’m paranoid!😂 its been such a long process that would suck lol ![]() Thanks everyone for the input! Im hopeful its the bushings, ill get it in the air and get some better pictures. Ill just stare at the back until then😂 |
