JCFL
Location: Caraquet, New Brunswick, in eastern Canada (600 miles east of Boston)
Photo - Connector at DME, can I remove cover
In order to access pins on the connector while it is connected to the DME unit, can I remove the cover off the white connector ?
The purpose is to examine with a multimeter if the DME unit is getting correct signals - with harness connected to DME.
Thank you.
PS I did search the Forum and just couldn't seem to find the answer.
Jacques
1986 911 Carrera Coupe - since April 2022
1982 911 SC - 2010 - 2017
1984 911 Carrera Coupe - 2006 - 2009
Old 08-03-2023, 01:02 PM
ROW '78 911 Targa
timmy2's Avatar
Pins are likely too far inserted to get a meter probe in to each one. Just see a bunch of wires.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-03-2023, 02:25 PM
Yes you can remove it.
There is a small Phillips head screw on the top (curved area). Unscrew that.
Then on the bottom there is a rubber sleeve, likely held with a zip tie, cut the zip tie.
Roll the sleeve down, then slide the white curved portion up. It should slide up pretty easily. It's a two part contraption.
There is a retaining clip that slides into the connector from one side.
Sometimes the retaining clip and rubber seal will fall out.. you want to make sure those stay on during re-installation or the connections will be loose.
Install is the reverse and add a new zip tie to clean things up.
Take pics and post here if you have any other questions
Old 08-03-2023, 04:12 PM
JCFL
Thank you for your help. Much appreciated.
Jacques
Old 08-03-2023, 05:03 PM
