JCFL
Location: Caraquet, New Brunswick, in eastern Canada (600 miles east of Boston)
Photo - Connector at DME, can I remove cover
In order to access pins on the connector while it is connected to the DME unit, can I remove the cover off the white connector ? The purpose is to examine with a multimeter if the DME unit is getting correct signals - with harness connected to DME. Thank you. PS I did search the Forum and just couldn't seem to find the answer.
Jacques 1986 911 Carrera Coupe - since April 2022 1982 911 SC - 2010 - 2017 1984 911 Carrera Coupe - 2006 - 2009 |
ROW '78 911 Targa
Pins are likely too far inserted to get a meter probe in to each one. Just see a bunch of wires.
Yes you can remove it.
There is a small Phillips head screw on the top (curved area). Unscrew that. Then on the bottom there is a rubber sleeve, likely held with a zip tie, cut the zip tie. Roll the sleeve down, then slide the white curved portion up. It should slide up pretty easily. It's a two part contraption. There is a retaining clip that slides into the connector from one side. Sometimes the retaining clip and rubber seal will fall out.. you want to make sure those stay on during re-installation or the connections will be loose. Install is the reverse and add a new zip tie to clean things up. Take pics and post here if you have any other questions Last edited by almostordinary; 08-03-2023 at 05:18 PM.. |
JCFL
Thank you for your help. Much appreciated.
