3.2 Speed & Reference Sensors...both bad at the same time...
After solving a no crank issue (poor wiring crimp by yours truly) I'm now chasing a no start after clutch job, starter, fuel lines, AC conversion, etc. Previous thread is here for reference
We problem solved a lot today on the no start: - Fuel pump fuse has continuity - DME is not the issue (swapped the sold state with previously functioning DME) - Terminal 86 on the DME has 12v - No fuel smell at the tail pipe - Fuel pump primes and can feel it vibrate through a screwdriver - Tach doesn't move on the crank - Starts with carb cleaner sprayed in the intake - 36psi at the fuel rail - CHT: 1.03 ohms at ambient 85 degrees F Drumroll... Reference Sensor AND Speed Sensor: 1&2 read 1031ohms 1&3 nothing 2&3 nothing It looks like BOTH are not properly functioning. Before I go and order these, is this something that happens? We speculated that maybe we knocked them when mating the engine to tranny but don't specifically recall this. Any thoughts before I go and order new parts? Appreciate all the help so far.
-Mike 1987 911 Carrera Coupe Last edited by mziggy16; 08-07-2023 at 03:16 PM.. |
Isn't 3 the shielding braid?
Did you connect them up to the harness correctly? They have the same style connectors going to the engine harness and it's easy to mix them up. Switch the middle and lower connectors and see if it starts. These are the three vertical connectors near the #3 intake runner. |
The page from the Bentley is below. This is what I was referring to. Still seems unusual that both would prove faulty at the same time.
-Mike 1987 911 Carrera Coupe |
1&2 Should be around 1000, so yer probably in the ball park.
In the Bentley manual, the > symbol means GREATER than 100,000 ohms. Infinite resistance is GREATER than 100,000 ohms. You're good to go.
Like I said, terminal 3 is the shielding braid and it should not be touching either of the two other wires. |
Also, the sensors should generate an AC voltage across terminals 1 and 2 with the engine cranking.
Given that…what are thoughts on the next test? Running a little low on options.
Swap the two lower harness connectors and see if it starts.
Also, are you sure of the ohm reading for CHT? If so it looks like the CHT is shorted. Certainly doesn't help startup as this simulates a very hot engine. But since ambient temp is 85F it should eventually start. So this goes back to the sensors. Have you tried to swap them as suggested?
Gilles RoW 88 Carrera coupé |
If it will run on starting fluid then the speed and ref sensor must be working. If either one id dead you will have no ignition spark at the plugs, so it wouldn't make any difference if you added starting fluid or not.
Swapped them. Same result
You state that "- Fuel pump primes and can feel it vibrate through a screwdriver". There is no prime feature of the original fuel injection system. there are aftermarket DME relays that incorporate a prime feature. what DME relay are you currently running? |
My last pair of flywheel sensors would ohm test just fine when they were cold. Just after warmup and driving for a while, they acted like a demon possessed them. The idle would go up to 2,500 on it's own, then die. I had a heck of a time getting in 1/2 a mile back home to the garage. After I replaced them, I heated them with my heat gun, and they started acting weird. I was happy to send them to the landfill.
I replaced the sensors, and "while I was in there" another head temp sensor and the car run like it should for the last 6 or 7 years and I hope for many more years. So yea, test the sensors, but when it doubt, replace them unless they are very new. If they are the original ones, replace them just because they will not last much longer. I considered them a consumable item. And they are not that expensive or hard to replace considering how much pain and suffering they can cause. They are like having a flat tire, and a dead battery at the same time. Annoying as can be.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
We did a second carb cleaner spray/test and it started but when we sprayed more in to see if it would wake up something fuel-related it backfired so we stopped. I think it would run if it were fed an appropriate amount of fuel, whether that be carb cleaner or gasoline. DME is a Focus 9 Solid State DME with the pump prime feature.
I don't have a record showing Speed or Reference Sensor replacement and they appear to be original.
1. a bad DME ECM (fuel injection section) 2. a bad DME relay - Focus 9s go bad too like the OEM relay 3. a bad fuel pump/fuel regulator 4. stuck fuel injectors 5. no 12V power on fuel injectors
Dave |
Pump and Regulator are getting 36psi to the rail. Could be injectors. What are the odds of ALL of the injectors being stuck? Would assume it’s power delivery to the injectors rather than all of them being stuck. And then there’s the DME ECM…is there a way to test this without swapping in a new one?
And the head temp sensor s just a while you are right there replacement item. The wire goes through the grommet, and getting the grommet back into place is frustrating enough to do that alone is a good reason to replace the three sensors as a unit. And do them one at a time, and mark the positions of the connectors top and on the flywheel positions BEFORE you do removal. If your fuel pump is original, replace that as well.
