rcm rcm is offline
rcm's Avatar
Question oel gauge flutter
howdy,
This gauge seems to stay pinned to the top side most of the time w/ occasional flutter. I'm assuming that I have a bad sender.? Tell me what you know.
BTW, I stop by this forum a few times a day and am learning a ton.
Thanks,
Rick
Rick
" too many people spend money they haven't earned to buy things they don't want to impress people they don't like" Will Smith
Old 06-11-2003, 01:04 PM
Hilbilly Deluxe
emcon5's Avatar
The dash oil guage is only to be read when the car is at idle on level ground and at operating temp.
As a general rule, trust of the dash oil level guage is something that it needs to earn. They are notorousely inaccurate.
However, if you check frequently with the dipstick (also checked at idle, engine warm/level ground), so you know how the guage reads you may find yours works fine. Mine does.
And to avoid messes in the future, don't fill the oil to the full line on the dipstick, fill it about halfway between the lines.
Tom
82 911SC Coupe
GTI Cup #43
Old 06-11-2003, 01:29 PM
Senior Member
Superman's Avatar
I had this problem. You have either a bad sender or a poor connection/wiring. The gauge pegs if there is no signal from the sender. Unplug the sender at the tank, for example, and the gauge pegs.
Mocha 1978 911SC. "Coco"
Old 06-11-2003, 01:31 PM
I had an oil temp gauge go bad such that it was pegged at the top most of the time with a little movement when the engine was warm. That was the sender.
Old 06-11-2003, 01:35 PM
Friend of Warren
Like Supe said it just may be a bad connection. I wrote about this a few weeks ago and what you can do about it. Go here:Simple Oil Pressure Sending Unit Tip
Kurt V
Old 06-11-2003, 02:32 PM
rcm rcm is offline
rcm's Avatar
Thanks guys, I'll dive in this weekend.
Rick
Rick
Old 06-11-2003, 05:29 PM
pwd72s's Avatar
Me too.
Old 06-11-2003, 05:46 PM
