3.2 miss out randomly
Hi
I have a 1986 3.2
Last week started to miss out the ignition randomly, specially on load
Sound like the ignition on wrong place
Already changed the follow without succes
- Spark plug + wire + rotor + distributor + fuel filter + ignition coil
- Fuel pressure ok
- DME relay replaced
- Other DME tested
The speed and ref sensor measure 1000Ohm
The CHT sensor in cold 2400Ohm warm 300ohm
Bit confused now what to do
Old 09-13-2023, 07:21 AM
Not sure if this is helpful or not, but a while back I was having some issues (starting problems IIRC), Anyway, someone mentioned that the resistance on the sensors isn't necessarily consistent as I had assumed. In my case I found it would very considerably! I replaced them and problem solved. To be honest your problem is very different that what I was dealing with but wanted to mention the resistance issue. Maybe Ischmitz will chime in and offer better help.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 09-13-2023, 07:44 AM
Check all your grounds
Sent from my Pixel 7 using Tapatalk
Old 09-13-2023, 08:03 AM
My sensors would test out fine, but when they got hot, they were flaky. I changed them out, and the car has been flawless ever since.
The other weird running issue I had was the old original coil was failing after working fine since 1985. There is no good replacement coil for a 3.2 Carrera, except to find an original old black used coil that works.
I have yet to see a new coil designed to work with a 3.2 DME G body 911, one with the proper voltages that are good quality.
Old 09-13-2023, 08:36 AM
Ground checked and cleaned, it is only 1 place above the cy,inder 1?
ordered the 2 speed sensors.
Thank you for the help!
Old 09-13-2023, 09:08 PM
JCFL
Location: Caraquet, New Brunswick, in eastern Canada (600 miles east of Boston)
Seppo,
at the beginning of the summer, I went through what sounds exactly like what you are currently experimenting. Especially with respect to load . . .
I did all the changes, relays, grounds, etc... that were suggested on the forum. It then turned out that my 37 year old fuel tank was rusted beyond repair, and the rust residue were clogging the fuel injectors.
Installed the new fuel tank, and voilą . . . no more " miss out ".
Jacques
1986 911 Carrera Coupe - since April 2022
1982 911 SC - 2010 - 2017
1984 911 Carrera Coupe - 2006 - 2009
Old 09-16-2023, 10:04 PM
Cairo94507's Avatar
I had an issue with my 3.2 and it turned out to be the coil. Never ever had a coil go bad, but it did. Replaced the coil and it was back to perfect. Good luck with the hunt.
'71 914-6 #0372
'17 Macan GTS
Old 09-17-2023, 06:44 AM
There is another on the front of the transmission that is exposed to a lot of road grime. There may be more, my 3.2 was out of the car when I got it and I haven't started putting it back yet.
Old 09-17-2023, 07:06 AM
