Bad CD Unit or Bad Starter?
I just got back from trying to help a friend with his '78 targa. It seems it died while he was driving so I went with him to check things out. We first checked for spark and there was none. So I recommended that we take the coil from my car and test again to see if this is the problem. I was thinking coil or CD unit. After switching out the coil the car would not even turn over? Was sup with that! I suggested to him that we try the CD Unit but as it was I was making things worse so he opted to not try the CD unit and have it towed to a mechanics.
Does anyone know what might have caused the starter to not turn over once we were just trying to replace the coil? The only thing I could think of is that we didn’t disconnect the battery and that we might have burned something. Other than that I’m spoofed. |
Sounds like a bad CD unit to me.
73 GTV - Alfa Romeo www.AlfaBB.com |
Any ideas on this one?
I believe the starter should still crank, even with a bad CD unit.
Senior Member
Bad ground(s).
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Sounds like you have two problems.
First, the engine should crank with or without a good or bad CD. Next, if the CD is a Bosch, it should buzz. If so, then check for a good spark. If no spark, a bad coil is possible but rare. Check for a good input signal to the CD with an ohmmeter, from the distributor. Check all +12v and grounds. Check out the website Systemsc.com (Diagnostics) for some troubleshooting hints. Good luck Loren Systemsc.com |
Senior Member
The ignition problem and the starter problem are independent. I'm with Doug. Clean the grounds. That's likely to help the starter problem, but the ignition problem is something else. Wiggle the two square connectors in the engine compartment.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
The ignition and cranking circuit do have something in common... the battery.
You may have a dead alternator and the car was operating on the battery until it fell below operating voltage. Maybe even a poor battery connection. This is just a guesstimate. Hope this helps, Sherwood Lee http://members.rennlist.org/911pcars |
Im just bummed because It seems that I made this guys problem worse and that hes going to go thru the whole hassel of calling a tow truck ($$$$). Any other thoughts would be appreciated. The car hasn't been picked up yet and I still might have a chance to save face. Last edited by smestas; 06-13-2003 at 12:19 PM.. |
"I thought about that as well and the cockpit gauge read that the battery was fully loaded. But did turn quickly to "0" when the key was turned. With no audible clicking sound from the starter. Is that normal?"
Simon, No, that's not normal. An unloaded, but partially discharged battery may indeed read 12+ volts. It's what happens when a load is placed on the battery that counts. Think of the cranking capacity of 8 AA batteries. Unloaded, the 8 AA's connected in series = 12 volts. However, an attempt to rotate a starter motor with this wimpy group would barely warm a conductor. Under normal conditions, the battery should remain above 9 volts while cranking. Typical engine operation voltage should be around 14 volts (if the alternator is working). If you want to attempt a face-saving maneuver, offer to swap your battery for his (assuming your battery is fine). Maybe this will work. The price is right at this point. BTW, don't screw it up. Positive cable to positive post, etc. But then again, that's JMO, I could be wrong. Sherwood |
Thanks for all the replies.
The tow truck beat me to it so I'll have to let you guys know how it all turns out. I think Sherwood hit the nail on the head and it was just coincidental that it (battery) went dead while I tried to swap out the coil. |
Simon,
I hope your friend sees your efforts as trying to assist rather than being the cause of his car's demise. have a nice weekend, Sherwood |
![]() Imagine my puzzeled look when the coil was swaped out and instead of the motor fireing up there was dead silence.
