| Registered Join Date: Jun 2019
				911 SC 1983 - Tunnel Layout - Whats all in there !
			Hi, I am building from a more or less bare shell. There are lots of conduits pipes and cables in the tunnel. I have the 2 fuel lines identified and the throttle and clutch cables. What else is in there and what can I remove. I don't have a brake booster for example. If anyone has a picture with everything in the tunnel of an SC that would be great. I have seen pictures for earlier models but nothing for an SC. Thanks in advance. Douglas. | ||
|  09-26-2023, 10:11 AM |
| Registered |
			Just replaced the tunnel lines in my 81 SC. I think the only thing there was the 2 lines and a metal rod that was under the same clip in the front hole.  Sent from my iPhone using Tapatalk
				__________________ John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. | ||
|  09-26-2023, 12:27 PM |
| Registered |
			These pictures were posted somewhere.
				__________________ 78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS | ||
|  09-26-2023, 12:48 PM |
| Registered |
			^^^ Nice info.
|  09-26-2023, 02:30 PM |
