skinnerd's Avatar
Who makes your LED headlights? Same Flat6Illumination?
Also, did you think about getting Damon Series 900 to build you a new engine shroud instead of painting yours? His are "factory" nice and reasonably priced I seem to remember.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 05-04-2024, 09:16 PM
I'm good with tools.
AG81's Avatar
skinnerd,
I had to switch gears on my headlights twice. I wanted 911Eleven Headlights. When I realized that wasn't going to happen I decided on 9Haus, after speaking to Jake, the owner. I am very happy I went this direction.
I did not consider having a engine shroud made. I didn't even realize that was a possibility. I had mine cerakoted. It looks pretty good. Thanks for the heads up on Damon Series 900.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 05-05-2024, 07:40 AM
AG81's Avatar
Cleanup and modifications continued today with the removal of the oil console.
This needs to be fitted with the thermostat Chuck sent along with my finned oil line plumbing kit.
02 996 4S
Old 05-05-2024, 02:24 PM
AG81's Avatar
Pictures didn't want to load in the previous post.
02 996 4S
Old 05-05-2024, 03:58 PM
AG81's Avatar
Waiting on parts is excruciating.....why did I decide on a 72???????
02 996 4S
Old 05-21-2024, 04:56 PM
Winter911's Avatar
Love watching the progress of this car.
Here is my '72 MFI someone butchered in the 80s. I plan to bring it back to a longhood and your car is giving me even more motivation. Jut gotta find body panels that fit my budget
Cheers.
Old 05-22-2024, 07:40 AM
AG81's Avatar
I don't know what is more difficult to believe. The fact that your car is a 72 or that someone actually did that to a 72. Wow that takes balls and money. I'm guessing that G body face lifts were a thing at some point. The 80's were a wild time. Good luck on your renovations.
02 996 4S
Old 05-22-2024, 03:40 PM
AG81's Avatar
Lots of thanks you's to go around while completing this oil console refurbishment.
From difficult parts to find to machining and fabrication this one had me at times.
It's done and so is the work on my oil pump so things can move forward with the motor.
The new CSF front fender cooler, finned Elephant lines, restored 72 oil tank and console is complete.
02 996 4S
Old 05-25-2024, 09:09 AM
AG81's Avatar
Mini Duck finished and installed:
Big thanks to fellow Pelican Jonny042 for his work on fabricating the part.
02 996 4S
Old 05-25-2024, 09:14 AM
tobluforu's Avatar
There was a day when early Porsche's didn't cost much, so modifying them wasn't really all that big of a deal. I paid peanuts for my car, but I sure wish I had hindsight, or I would have kept mine somewhat stock.
I just changed the oil on my 72 and was looking at the area where the oil tank is located. And thought, man do I need to clean that area. Looking at yours, it's clear mine needs a ton of work to look halfway as nice as yours.
Great job.
Luv your plate.
Old 05-25-2024, 09:15 AM
AG81's Avatar
tobluforu, the shear amount of crap and dirt behind my oil tank was dumbfounding. Stuff just kept falling out. I had to clean the tank to attack the pin holes in the bottom. The oil console needed modifications for the front cooler I added. Along the way everything got a good cleaning.
02 996 4S
Old 05-25-2024, 02:36 PM
AG81's Avatar
I am taking the car off the lift this morning and flipping the car around.....
02 996 4S
Old 06-01-2024, 11:25 AM
Administrator
Matt at Pelican Parts's Avatar
Looking great! Loving the continued updates on this project!
Old 06-04-2024, 04:22 PM
AG81's Avatar
Thanks Matt.
02 996 4S
Old 06-05-2024, 11:13 AM
AG81's Avatar
UPDATE:
THe interior is finish..... that is until I decide to modify something. But most of what I wanted to accomplish is done.
The Tach arrived after 9 months.
It will be nice to get the motor finished so I can move the car out and get better pictures.
02 996 4S
Old 06-16-2024, 09:22 AM
skinnerd's Avatar
Looks great!
I like mostly black interiors.
It will be interesting to see what you think about the orange tach face as you’re driving around.
Doug
Old 06-16-2024, 11:57 AM
As others have said, really nice work. What I didn't read after a few times through what's the wheel size and ground to fender lip measurement? Mines lower, PeteKZ is higher and my rear suspension is next on my list. PP has red Koni's on sale for a SWB and I'll order those before the sale is over. Support our host!
Old 06-17-2024, 07:58 AM
AG81's Avatar
The wheel size is 16x7. I have not finished the ride height as my engine is out !!! The rear was pretty darn close when I dropped the engine. The front was about 10mm high. I didn't worry too much about either as that can and will be finalized after my engine goes back into the car.
02 996 4S
Old 06-17-2024, 10:53 AM
scumbag
Looks great, Steve!
You've been busy on your car while I've been busy with everything else.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
AchtungKraft #009 - IG: @doktor_b
Old 06-22-2024, 07:31 AM
AG81's Avatar
Thank you Chris..... yes you have I have followed along on Insta.
02 996 4S
Old 06-22-2024, 08:09 AM
