Ryan_Cunningham's Avatar
1972 Steering Column Play - Will the 928 Part Work?
Noticed some play in the steering wheel the other day and went to research the fix. Removed the Momo wheel and there is significant play in the column in the vertical axis after tightening the shear bolts behind the dash. Probably 2mm of play which is certainly noticeable driving.
From the images and videos I’ve referenced I’m not sure that the steering shaft bearing below will work for my ‘72 as it only is listed to fit my ‘81 SC.
Anyone know if it’ll work?
My steering column.
Thank you for any assistance.
And a link to the video since I can’t determine how to embed YouTube videos.
https://youtube.com/shorts/0qsPxQ-eiMQ?si=wnfALXkTqp7Y455F
"Purists are the Karens of motorsports.
IG - Iron_Dad_Moto
1972 Porsche 911 - Long Term Project. 3.6TT/G96.50
1981 Porsche 911SC - In Progress.
F/A-18C/D, F-15C, F-35B/C
Old 10-03-2023, 04:56 PM
Different setup, won't work. Is the bearing cup and spring on the shaft?
206 637 4071
Old 10-03-2023, 09:35 PM
HarryD's Avatar
Different setup.
This thread can get you started. https://forums.pelicanparts.com/porsche-911-technical-forum/956638-help-1972-911-steering-wheel-bearing.html
You can order the parts though Pelican with these part numbers:
Spring: 914 347 713 00
Support: 695 347 725 00
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-03-2023, 11:45 PM
Following
Old 10-04-2023, 02:23 AM
Titanium User
I had some play on my early car and the support 695 347 725 00 solved my issues.
Buy some Titanium Lug Nuts!
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html
ig: @ti_porsche_products
Old 10-04-2023, 05:32 AM
Thank you HarryD, spring and support ordered. My Haynes manual, which I haven't referenced since buying the Bentley for my 1981, has a good image of the steering column for the '72.
Will report back once the parts are installed!
IG - Iron_Dad_Moto
Old 10-04-2023, 10:12 AM
Apparently I’m also missing #27. Does anyone know what that part number is?
IG - Iron_Dad_Moto
Old 10-10-2023, 07:21 AM
Titanium User
Turn signal cancel - 90161332505
Old 10-10-2023, 07:30 AM
Pelican should be paying you. Best service ever!
IG - Iron_Dad_Moto
Old 10-10-2023, 07:32 AM
DG567,
Night and day difference in the column! I also tightened the two bolts behind the gauges which seems to have helped as well. Thanks for a much improved ride to work this morning!
IG - Iron_Dad_Moto
Old 10-12-2023, 10:10 AM
tobluforu's Avatar
More pics.
Old 10-13-2023, 04:31 AM
Titanium User
Originally Posted by Ryan_Cunningham View Post
DG567,
Really makes a huge difference in the feel after you have all the right parts in there, right?! I had the spring in my column but was missing the bushing.
Sweet wide body!
Old 10-13-2023, 05:04 AM
Originally Posted by tobluforu View Post
More pics.
It’s a work in progress.
IG - Iron_Dad_Moto
Old 10-13-2023, 09:30 AM
Sweet wide body!
Huge difference!
IG - Iron_Dad_Moto
Old 10-13-2023, 09:31 AM
