Pelican's "Search" Function??????
How do I search for the actual string "no spark?" When I type in
no spark
"no spark"
'no spark'
no AND spark
I get everything that has the word "spark." I just want responses/threads with the string "no spark." For example, I do not want to see threads about spark plugs.
Thanks.
Old 01-12-2004, 09:19 AM
Gon fix it with me hammer
svandamme's Avatar
eeh,
have you tried to do what it says on the search form?
Basic query: separate your search terms with spaces.
Advanced query: Join words with AND, OR and NOT to control your search in more detail.
Add asterisks (*) to use wild cards in your search (*bullet* matches vBulletin etc.)
it's the NOT that would do the trick
Stijn Vandamme
BIMDIESELBMW116D2019
Old 01-12-2004, 09:27 AM
CHILI's Avatar
Originally posted by svandamme
eeh,
Ok, I'll bite (and show my ingnorance). I too, don't understand how to use the function properly. I always have to sift through tons of threads that have just one word for which I am looking.
So, can you give the example of how he should be searching? you say it's the NOT that's key. How should it be typed in the search field?
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 01-12-2004, 09:47 AM
Hilbilly Deluxe
emcon5's Avatar
Looks like it ignores anything shorter than 3 letters.
In fact, if you search for most 2 letter combos, it gives an error that it is too short.
2 letter words seem to be ignored without an error. I tried is, at, as, to and no, and got "no matches". If you put in something that isn't a word, like "ai" it gives this error:
"The search term you specified (ai) is under the minimum word length (3) and therefore will not be found. Please make this term longer.
If this term contains a wildcard, please make this term more specific."
In other words, it's not a bug, it's a feature.
Tom
82 911SC Coupe
GTI Cup #43
Old 01-12-2004, 10:01 AM
svandamme's Avatar
wires NOT spark
got me a list of threads where wires are discussed but no sight of the word spark
if you type in
wires not spark
you'll get a list with topics where combinations of the words wires,not and spark are used
although the not maybe ignored as mentioned above, dunno
wires AND spark will produce only topics in which both are used
if you want a decent search you should do something like
green AND wire NOT spark NOT plugs NOT red
Stijn Vandamme
Old 01-12-2004, 10:17 AM
Friend of Warren
yes the less than 4 letter words will not work in search. really sucks when you are searching for something like O2 sensors
Kurt V
Old 01-12-2004, 10:19 AM
Larry Harris's Avatar
Try "engine no go rmm rmm" Sparky mad, sparky go home.
Just trying to help
2001 Turbo
Old 01-12-2004, 10:26 AM
Super Moderator
cstreit's Avatar
I think if you have a two letter word, you can add an asterisk to fake out the system.
no*spark (no spaces in that one) brings up no-spark
no* AND spark seems to hang it up...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-12-2004, 11:14 AM
Author of "101 Projects"
Wayne 962's Avatar
The lack of a phrase search ("no spark") is a limitation of the current software used to run the BBS. I have no control over this, but I think that the next version (which has been "coming soon" for a year and a half) will support this.
-Wayne
Old 01-12-2004, 11:59 AM
Thank you guys. I have been doing MIS forever and I thought it was time for me to switch careers (maybe a "pimp").
The limitation really s_cks!
Wayne,
In our industry, excluding me, we do not use the term "limitation." The politically correct term is 'opportunity.'
Old 01-12-2004, 01:47 PM
svandamme's Avatar
and internally it's called an annoying bug we will fix at a later time,
read : when we feel like it , or when upper management makes a big deal out of it and tells us to drop everything to fix it
Stijn Vandamme
Old 01-12-2004, 01:51 PM
svandamme's Avatar
not dissing you Wayne, was referring to my own job !!
Stijn Vandamme
Old 01-12-2004, 02:03 PM
Wayne 962's Avatar
You know, I'm actualy working on something right now (today), and I may be able to incorporate this feature.
I'm re-writing our search engine to pull results from:
- Parts Database
- Catalog
- Technical Content
- DriveWerks Accessories
- Pelican BBS
based upon your search criteria. I just finished the BBS integration last night - I wonder how difficult it would be to add phrase searching to my search routine...
hmmm...
-Wayne
Old 01-12-2004, 02:08 PM
TedSlick's Avatar
a phrase that can be a real problem is:
"CV joint"
hardly anyone discusses these by calling them "Constant Velocity joints", so the two-letter-word error will cause you to miss lots of good info.
I think I ended up using "joint AND axle"
using "joint" alone results in a bunch of unrelated 'nostatic' posts ...j/k
Old 01-12-2004, 03:19 PM
"FK Seats" is a bad search term too ! .....
Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-15-2004, 09:23 AM
