Pelican's "Search" Function??????
How do I search for the actual string "no spark?" When I type in
no spark "no spark" 'no spark' no AND spark I get everything that has the word "spark." I just want responses/threads with the string "no spark." For example, I do not want to see threads about spark plugs. Thanks. |
Gon fix it with me hammer
eeh,
have you tried to do what it says on the search form? Basic query: separate your search terms with spaces. Advanced query: Join words with AND, OR and NOT to control your search in more detail. Add asterisks (*) to use wild cards in your search (*bullet* matches vBulletin etc.) it's the NOT that would do the trick
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
So, can you give the example of how he should be searching? you say it's the NOT that's key. How should it be typed in the search field?
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please ![]() Chad aka "Chili" 1974 Base coupe in Carrera outfit. No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.) My car http://www.pelicanparts.com/gallery/CHILI 1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras. |
Hilbilly Deluxe
Looks like it ignores anything shorter than 3 letters.
In fact, if you search for most 2 letter combos, it gives an error that it is too short. 2 letter words seem to be ignored without an error. I tried is, at, as, to and no, and got "no matches". If you put in something that isn't a word, like "ai" it gives this error: "The search term you specified (ai) is under the minimum word length (3) and therefore will not be found. Please make this term longer. If this term contains a wildcard, please make this term more specific." In other words, it's not a bug, it's a feature. Tom |
wires NOT spark
got me a list of threads where wires are discussed but no sight of the word spark if you type in wires not spark you'll get a list with topics where combinations of the words wires,not and spark are used although the not maybe ignored as mentioned above, dunno wires AND spark will produce only topics in which both are used if you want a decent search you should do something like green AND wire NOT spark NOT plugs NOT red
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 Last edited by svandamme; 01-12-2004 at 11:21 AM.. |
Friend of Warren
yes the less than 4 letter words will not work in search. really sucks when you are searching for something like O2 sensors
Kurt V No more Porsches, but a revolving number of motorcycles. |
Try "engine no go rmm rmm" Sparky mad, sparky go home.
Just trying to help
2001 Turbo |
Super Moderator
I think if you have a two letter word, you can add an asterisk to fake out the system.
no*spark (no spaces in that one) brings up no-spark no* AND spark seems to hang it up...
Author of "101 Projects"
The lack of a phrase search ("no spark") is a limitation of the current software used to run the BBS. I have no control over this, but I think that the next version (which has been "coming soon" for a year and a half) will support this.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thank you guys. I have been doing MIS forever and I thought it was time for me to switch careers (maybe a "pimp").
The limitation really s_cks! Wayne, In our industry, excluding me, we do not use the term "limitation." The politically correct term is 'opportunity.' |
and internally it's called an annoying bug we will fix at a later time,
read : when we feel like it , or when upper management makes a big deal out of it and tells us to drop everything to fix it
1+ million posts, lightning fast speed. You have to sacrifice one thing for another...
-Wayne
not dissing you Wayne, was referring to my own job !!
You know, I'm actualy working on something right now (today), and I may be able to incorporate this feature.
I'm re-writing our search engine to pull results from: - Parts Database - Catalog - Technical Content - DriveWerks Accessories - Pelican BBS based upon your search criteria. I just finished the BBS integration last night - I wonder how difficult it would be to add phrase searching to my search routine... hmmm... -Wayne
a phrase that can be a real problem is:
"CV joint" hardly anyone discusses these by calling them "Constant Velocity joints", so the two-letter-word error will cause you to miss lots of good info. I think I ended up using "joint AND axle" using "joint" alone results in a bunch of unrelated 'nostatic' posts ...j/k
"FK Seats" is a bad search term too !
.....Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
